Hertz_So_Good Posted August 1, 2015 Report Posted August 1, 2015 Hey fellow bass heads.. I am going to start my next project soon, and I need some input. The system will be going in a 1996 Jeep Grand Cherokee. I am wanting to do a 4th order wall, and I am curious if 6 SA 15s would fit? I have talked to one box builder, and he said 6 wouldn't fit. I am in no way discrediting what he said, But I just want to get some other box builders input on if they think 6 would fit. Thanks in advance
ChevyBoy95 Posted August 1, 2015 Report Posted August 1, 2015 Guess what.... no one here can help you if you don't supply maximum dimensions to work with. We don't go by "it looks like it will fit." Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
dsw422 Posted August 1, 2015 Report Posted August 1, 2015 it can be done.. https://www.youtube.com/watch?v=R8MVKH5fi4E 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
TaylorFade Posted August 1, 2015 Report Posted August 1, 2015 It'll totally fit. Now whether it meets your goals is a completely different story. I figure you need.... around 40 cubes gross. At least. You have 40+?
Hertz_So_Good Posted August 1, 2015 Author Report Posted August 1, 2015 Guess what.... no one here can help you if you don't supply maximum dimensions to work with. We don't go by "it looks like it will fit." No need to be an ass. I thought maybe they would know the dimensions since its a pretty popular vehicle for systems.
Hertz_So_Good Posted August 1, 2015 Author Report Posted August 1, 2015 I have 3' 6" wide 3 feet tall and 4 feet deep. That leaves about 1 inch behind the b pillar and enough space for amps and batteries in the rear. As for my goals. I'm not really someone who competes, so something that plays low and clean is fine with me. Also, yea I love Galen's jeep. When I mentioned it to the box builder, he mentioned how different subs need different space. and that the SA's will require more than xls.
Cj Kumz Posted August 1, 2015 Report Posted August 1, 2015 Based on your dimensions you have around 37 cubes gross. That's too low if you looking at building a forth order box. Personally I would advise you doing a ported box instead cause you will need 24 cubes net so you have alot of room for displacements and stuff. Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!!
hispls Posted August 1, 2015 Report Posted August 1, 2015 You will likely wind up with a bit less space than you think after you start layering up wood and bracing and an adequate port. If you plan to build right up to the B-pillar I hope you're short, I'm 6'0" and I need my seat back a good bit behind the rear door's window line to be really comfortable driving. Also 6 15's would be very tight unless you angled them. My baffle has 4 15's and IMO bare minimum port area out of the space left over. I might ask, why do you feel you need 4th order? What sort of bandwidth to you expect to be able to play? What are your goals? IMO considering after all is said and done the woofers will likely be only 15-20% of the total cost, have you considered stepping up to a higher line of sub and possibly going fewer of them if you're running into budget cap?
DrewJones Posted August 1, 2015 Report Posted August 1, 2015 I'd aim for say 4 15"s in a 4th if you want a wide range and still be loud.If you want number. Normal flat wall. TEAM SOUTH Bassahaulic Productions The ONLY Bright Atlantic Blue DiamondBoxx L Drew Jones Bassahaulic Productions 4 SSA ZCON 15"s 2 Sundown SCV-6000's 6 AGM G31's 161.6 @ 40Hz Outlaw 159.8 @ 36Hz Legal ┌∩┐(◣_◢)┌∩┐
Hertz_So_Good Posted August 3, 2015 Author Report Posted August 3, 2015 You will likely wind up with a bit less space than you think after you start layering up wood and bracing and an adequate port. If you plan to build right up to the B-pillar I hope you're short, I'm 6'0" and I need my seat back a good bit behind the rear door's window line to be really comfortable driving. Also 6 15's would be very tight unless you angled them. My baffle has 4 15's and IMO bare minimum port area out of the space left over. I might ask, why do you feel you need 4th order? What sort of bandwidth to you expect to be able to play? What are your goals? IMO considering after all is said and done the woofers will likely be only 15-20% of the total cost, have you considered stepping up to a higher line of sub and possibly going fewer of them if you're running into budget cap? I could consider stepping up to a beefier sub, but that means more power. and more power means more $ lol. It is still very early in this build planning and a lot could change. I was just curious if 6 in a 4th could fit. also, I know that I should allow for the wood and such.. Those were just my maximum dimensions.
