d-nice88 Posted August 7, 2015 Report Posted August 7, 2015 Ok so on break im going to the store playing my music and all of a sudden my 4 ch amp and 2 fans shut off but the sub amp radio and eq stay on. When I got to the gas station I turned my radio off and the car off but the sub amp and eq stayed on idk wtf just happened. I had to unplug the power and ground to the relay but it still stayed on. So I just unplugged the remote to the sub amp then everything shut off. Any idea why ??
Skullz Posted August 7, 2015 Report Posted August 7, 2015 Check all fuses and wiring and find the one that short out or lost connection. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
d-nice88 Posted August 7, 2015 Author Report Posted August 7, 2015 Could it be a short ? I had my car parked in the sun and my amps were exposed to direct sunlight and I live in texas and it was like 105 degrees outside prolly 115 in the car
jcarter1885 Posted August 7, 2015 Report Posted August 7, 2015 Could it be a short ? I had my car parked in the sun and my amps were exposed to direct sunlight and I live in texas and it was like 105 degrees outside prolly 115 in the car I doubt its the heat, you aren't the only person in Texas with a system and this has never happened to me. Make sure your connections are good, also where does the remote wire from the sub amp go to? More info about your system is needed. Nav-TV Zen V Audio Interface AudioControl DM-608 (2) Stevens Audio Neo-Comp Full-Size Horns (4) Faital Pro 6PR160 6.5" AudioControl LC-6.1200 (1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz Ampere Audio AA3800.1 Odyssey ODP-AGM48 Battery (Starting) Odyssey ODX-AGM31 Battery (Trunk) Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
Broke_Audio_Addict Posted August 7, 2015 Report Posted August 7, 2015 Check the wiring to the relay. Or try replacing them relay itself, it's not unusual to get a relay that goes bad quick. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
d-nice88 Posted August 8, 2015 Author Report Posted August 8, 2015 I have the remote from the hu going to the relay then from the relay to sub amp 4 ch amp and 2 fans. I will buy a new relay and re wire everything with new wire. I got the relay from autozone spdt single pole 40 amp relay it was only 6 bucks.
d-nice88 Posted August 10, 2015 Author Report Posted August 10, 2015 ok so now idk wtf is going on. got another relay wired everything back up and still nothing. when i hook up my remote from the hu/eq to the switch part of the relay the eq turns on and wont turn off unless i unhook the remote from the switch. when i got everything hooked up i turn the car on and none of my other stuff comes on. my sub amp 4 ch amp and 2 fans all of them dont turn back on idk wat the hell is goin on. any one got an idea?
islandpride684 Posted August 10, 2015 Report Posted August 10, 2015 Check all your connections on the relay going out to the amps and all the connections going in on the relay....where is the relay located? Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
d-nice88 Posted August 10, 2015 Author Report Posted August 10, 2015 in the trunk with the amps and fans
d-nice88 Posted August 10, 2015 Author Report Posted August 10, 2015 ima have to pull out the sub box and work on everything when i have the time its so weird tho. it was bumpin just fine then outta no where the 4 ch died and the fans cut out. only thing that stayed on was the sub amp and the eq
