Pair of 21" subs on my hhr?
sbg
With a large motor and stiff suspension it would be safe to guess low q and low-ish FS just from the mms. Going with DD type box ratio perhaps tuning on the low side would likely give good results I'm guessing.
Yeah possibly, I'm sure that cone & coil weight a ton, but the stiff suspension is going to raise the Fs quite a bit. Just compared to what I've heard the specs are for the Tantric 24" I wouldn't be surprised the the Q is higher than you'd think too.
Anyway, its pointless to speculate, the only way to know is to measure it.
Builds:
I don't know what the t/s secs are or even know who to get them. They were full custom build. Guy who had them,didn't even,know what power they could take. But ibdos get them. Thinking of running 1 or trading them for a good pair of 15s
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Check out the SMD tool map, or try to find someone with a im-sg. That will help you get T/S specs on the driver, I know there are other devices. I just don't know their names, and might have lesser availability.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Run 'em man. It's a sin to run too small of a box, yada yada yada… People run too small of boxes all the time and still get good sound. (think prefab boxes)
Not the best sound they can get, but good sound. (Good enough for them)
Run 'em even if the box is too small, just so you can say you had two 21"s in an HHR. Two 21"s will get down and sound awesome even in a compromised enclosure. It's two 21"s. They will move tons of air, even if they're not moving the most air they could move.
Do it man. Just do it.
this
Run 'em man. It's a sin to run too small of a box, yada yada yada People run too small of boxes all the time and still get good sound. (think prefab boxes)
I know. Everyone keeps telling me the same thing haha
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
I seen a guy online running 24s in a infinite baffle. Think that's something I could do in the hhr? I know nothing about what or how do go about that..
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
If you had a way of creating a separate airspace like the cover in a hatch you could but the results would be less than stellar. You wouldn't have much airspace to work with either. It depends allot on the QTS and vas of the sub's. You could always cut out the floor and build a super baffle and vent then to the outside but level of fab would be absolutely mental. Sealed box for 2 21" sub's should get plenty loud. I wouldn't recommend ported on account of the space requirements and it would most likely have a peaky response due to less than optimal size.
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
  • Who's Online   0 Members, 0 Anonymous, 2258 Guests (See full list)
