Alt whine or fuel pump?
I disconnected all wires from the amp, but when I was isolating the crossover I only disconnected the + wires, I need to disconnect all from it but with my ear to the tweeter I was able to beep out Moors code with the spade connector for the tweeter on the crossover tweeter terminal so I am for sure getting noise from my wires or crossover. I have 16ga wire with about a 12' run for the fronts at 100Wrms so I think that is adequate (I have read that too small of speaker wire over distance can accept noise easier)
Have I gone bat shit crazy?
What do your grounds look like?
Post pics of the install if possible it really helps sometimes.
Grounds have been wire wheeled clean to bare shiny metal, bolted down. I'll grab a pic of grounds shortly but my install is trashed trying to track this down.
Doesn't matter if it's trashed nobodys install looks pretty when working out a problem.
I just want to see how well and where it's grounded
You sir have a ground loop problem.
Hook everything back up, Run a ground wire from your front battery to that distribution block and tell me if the noise goes away.
Even just a temporary jumper through the window is fine.
Grounds, a JL 1000/1v1, crescendo c1100.4, head unit, and a 5' run of 1/0 straight to the factory battery - terminal through a Knu bassik terminal.
Imo you need to re ground directly to the frame. Sheet metal just isn't good enough. And I think it's better to have a dedicated ground per wire, could be wrong though?
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
  • Who's Online   0 Members, 0 Anonymous, 835 Guests (See full list)
