Editing Clipped Music
Well I finally got educated on the idea of clipped music. I figured if it was purchased from a reputable place and not boosted it would be clean. Turns out after running it through audacity it is not. Is there a way I can alter the music to make it play clean?
1999 Lexus GS 300
Pioneer DEH-80PRS
Singer 240 Amp (Will be installed later)
Northstar Group 31 & 24
Sundown SCV-4000
Rockford T400-4
2 12" CT Sound Meso
CT Sounds 6.5 Meso Components
CT Sounds Tropo 6.5
Depends what type of clipping it is. You can clear some of it up by using methods similar to this. Its not perfect as the original audio was damaged to start with, but it does help.
Hammerdown... 1%
Don't worry about song clipping, unless its audibly distorted (example below), as long as your source (Headunit/Amps) have a clean signal then you should have no issues
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
holy hell
Hammerdown... 1%
  • Who's Online   1 Member, 0 Anonymous, 500 Guests (See full list)
