SQ'd 6.5" questions
matt-man
Question. Why not try the sq components?
Soundqubed is out of stock, so unless he buys used, or has another source he can not get his hands on them
I will admit my bias toward SoundQubed but a better choice for you application may be: http://www.soundqubed.com/2-Way-65-Coaxial-Speaker-Sold-As-Pair_p_250.html You never mentioned how many watts the amp you will be using was, but if you do not want to mount new tweeters this could be the simplest, and best answer for you. Wishing everyone a wonderful day!
I was wanting the pro's because a review for the coaxial's said that the pro's were a better speaker for the same price. My amp is a Soundstream PCA2.260 at 260 watts
That will make them scream I think. Are you going try to use your factory tweets with them, or are you going to get the TH25's to go with them?
I plan to have this car for no more than a year and the factory tweeters are in a hard-to-get spot. So the stock tweeters are staying in there unless the go out on me
2003 Kia Sedona A.K.A Bob
2 Alpine Type-R 12's @ 2Ohm
Pyramid Audio PB3818 @ 2Ohm
JVC Arsenal KD-AR565
Unless someone has had both, they won't know how they compare. The only thing I or anyone else can tell you is to listen to them yourself. Find what is in your budget, buy and try them, if it's not what you're looking for, return them. As long as you haven't damaged them, they will be returnable.
Specifications
Model QX-652
Magnet Weight
Woofer Coil Diam 30mm
Coil Impedance 4.0 Ohms
Sensitivity 91 dB
RMS Power
55W
Peak Handling
250W
Overall diameter
6.5"
Mounting Depth
2.41"
Cutout Diameter
5.75"
Freq Response 40Hz to 22kHz
Skar Audio RPX65
•6.5" Coaxial 2 Way Speaker System
•Sold as a Pair
•RMS Power : 100 Watts (Pair) / 50 Watts (Each)
•Max Power : 240 Watts (Pair) / 120 Watts (Each)
•3/4" (30mm) High Grade Silk Dome Tweeter
•Microfiber Paper Mid-Woofer Cone
•1" KSV Voice Coil
•Rubber Surround
•4 Ohm Impedance
•Resonance : 76 Hz
•12 Oz Ferrite Magnet
•Rubber Magnet Boot Cover
•Frequency Response : 80-20,000Hz
•Sensitivity : 88dB
The Soundqubed coaxes have a higher sensitivity, and a broader frequency response. They also have an extra 5 watts on the RMS power rating according to the specs. I hope this helps.
How do these compare to the SoundQubed coaxial's?
  • 3 weeks later...
SpecificationsModel QX-652Magnet WeightWoofer Coil Diam 30mmCoil Impedance 4.0 OhmsSensitivity 91 dBRMS Power55WPeak Handling250WOverall diameter6.5"Mounting Depth2.41"Cutout Diameter5.75"Freq Response 40Hz to 22kHzSkar Audio RPX65•6.5" Coaxial 2 Way Speaker System•Sold as a Pair•RMS Power : 100 Watts (Pair) / 50 Watts (Each)•Max Power : 240 Watts (Pair) / 120 Watts (Each)•3/4" (30mm) High Grade Silk Dome Tweeter•Microfiber Paper Mid-Woofer Cone•1" KSV Voice Coil•Rubber Surround•4 Ohm Impedance•Resonance : 76 Hz•12 Oz Ferrite Magnet•Rubber Magnet Boot Cover•Frequency Response : 80-20,000Hz•Sensitivity : 88dBThe Soundqubed coaxes have a higher sensitivity, and a broader frequency response. They also have an extra 5 watts on the RMS power rating according to the specs. I hope this helps.
5 watts means nothing
True, but it is still a fact though right? I did not make it up, there is no bias, it is just a number.
OP this is what a QP MR 6.5 looks like next to a stock Mitsubishi speaker.
12041982_10100458021294182_520563174_n_z
12033860_10100458021279212_848787498_n_z
  • Who's Online   0 Members, 0 Anonymous, 1089 Guests (See full list)
