Eb flex Welding Cable
All I use
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I was thinking about this as well. Are there, any downsides to run it? Vs ofc?
Pioneer avn p4004 dvd for now
Jl e4300 replaced
Polk audio 4000.4 high & mids for now
Titanium 2000.1 subs amp for now
Crescendo BC2000D on the way 9/11 home at last
Infinity kappa 52.71
Infinity 3032cf
2 Memphis c3 15 d4
General Construction:
Conductors:
NEMA Class K, 30 gage, Bare Bright Annealed and Stranded, Electrolytic, fine Copper wires.
Jacket:
Premium Poly-XL™, High Energy Electron Beam cross-linked synthetic elastomer with polyester release barrier. Temperature range of +105°C to -40°C. Specifically engineered for the welding industry.
I don't see, anything about oxygen.
Jl e4300 replaced
Infinity 3032cf
2 Memphis c3 15 d4
Oxygen content really only has a impact on corrosion resistance, conductivity is the almost the same in ofc vs Plain old copper(within 1%)
Most welding cable is "ETP"
The most popular form of pure copper is the standard electrical wire grade of copper (C11000) contains 99.95% Cu, 0.03% O2, and less than 50 ppm metallic impurities. It has a high electrical conductivity, in excess of 100% IACS. In the as cast form it is called electrolytic tough pitch (ETP) copper.
IIRC... it has to be < 0.001% to be classified as "oxygen free". But it should be noted that C10200 copper (OF) isn't any more conductive than ETP. And even the most pure magic fairy dust C10100 that is 99.99% pure copper is *only* 1% more conductive.
Conductors:
Jacket:
Either did I, that's why I asked.
I can't find any evidence of this. Can you cite your source?
Oxygen is purposely injected during smelting to scavenge impurities.
  • Who's Online   0 Members, 0 Anonymous, 709 Guests (See full list)
