Think i can get the 150db?
sbg
If it's just the one woofer 8bd is a lot to gain by just uppung power, even that much.
At first I thought you ment to use both but after reading again I guess you mean only one? I see there's not much space left in that car, unless you go burp box :P
If you're not competing you should go with what seems the loudest most brutal to a person in the car, with a meter you'll just be tempted to tune higher and ruin any low end extenstion for a good number. A 150 is cool but see it as a great bonus if you get there someday outside of comps. Now if you can get it so sound good, get low AND loud on meter that's where it gets interesting B)
The best woofer setup I've heard isn't the one that metered the loudest
Just took the small amp out of my other car that was goes on a pair of sundown E12s
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Yep just 1 one sub for now, as I'm not wanting to wall it just yet, Shit with 2 of them 150 no problem. I got a 12k amp on tap if I run the pair
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Sub don't even move on the 1k amp. I was told that they are good for 6.5k of clean power each. Well I will have it all on the 3700 and what not in the next few days. And will meter again. Its a big sub but still less cone area then 2 15s and 4k in power. So if it don't do 149 150 I can't cry.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
I just put the sub in today, didn't even tune the amp. Took a vid. Nothing cool or whatever, but you can see the sub is not moving like at allhttps://youtu.be/p_EnImyB8Rk
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
How in love with that box are you? I can bet better numbers in the existing setup are to be had with a different enclosure.
It's just a first box. I have the other 21, so I will put that sub in this one and out it for sale and build a new one. Most of the time I build a few boxs before I find the "one". Kinda hard in this hhr, as for now in want to keep it behind the c pillar. Not much space to work with at all.by his 7cu ft box is max. Think the next box is going to get some round ports.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
This box is 7cu ft net
130" port area
17" port per foot
45s in box to help with air flow.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Got the 3700.1 in and one of my d3100s in. Man it got way louder. Going to,meter tomorrow if I have time. Thinking 148
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
how did the metering go?
Fidelity
Built to Last
Team Sound Asleep
24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/
2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3
2 DD M3b
Maxwell 2.7V 3000F Supercapacitors
Pioneer DEH-80prs
Focal P165 V30 components
Rockford Fosgate T-400.4
  • Who's Online   0 Members, 0 Anonymous, 3369 Guests (See full list)
