Im in no way recommending you to do this but back when I had my sierra I was running a sa8 v2 on an ab 100.1 @ 1ohm and it straight got down on 1500w
Used to have a loud truck
2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq
2013 F-150 limited, MPT Tune, leveled on 35"s
that was the TC epic, the AA didnt like 2k going to it and toasted the coil, the sa8 took a beating and kept on playing
should just be able to chop the port a bit. I would do an inch or half inch at a time.
Please do NOT take offense, I'd throw that box away. The craftsmanship looks pretty sketch. I'm not sure if that is silicone or drywall mud on the outside but it shouldn't be there. I'd rebuild with better cuts next time and a well fit/built box.
Regarding your issue, regular cabs for do well with the windows up. You lose all kinds of output when you seal them up. Adding a second sub would definitely be the easiest way to get louder.
none taken. The box is pretty solid. Inside and out. It fits perfectly behind my seat. I can still put my seats all the way back. I think I'm going to get another sub and place one behind each seat. Ported of course. If possible. It sounds amazing with the windows down. Windows up its just missing something
Posted (edited)
The box doesn't look very solid but if it is acceptable for you I guess that's all that matters. The guy that built it, does he have any prior fiberglass experience or skills with a saw?
Edited by CleanSierra
Posted (edited)
Regarding the sealed up dilemma, just FYI my regular cab truck does a 150+ at the headrest and I'm lucky if it does a 147 sealed up. Regular cabs are just that way man, if you want louder sealed, add power or number of subs
