Wehan Posted October 8, 2015 Report Posted October 8, 2015 Presuming you're talking about the alt to under the hood batt connection, and not a long run to the amp(s), then I agree with hdorre. Just a run of 1/0 from alt to batt, no fuse is what I do. The odds of you creating enough current to damage that short of a run is it won't happen. i think of fusing that wire as more of a fuse for the battery's sake, not so much for the alternator. i don't fuse that lead, though, because it's shorter and safer if wisely run. The alternator SHOULD detect the short and shut down, as for the battery at the other end...not so much.
MrSkippyJ Posted October 8, 2015 Report Posted October 8, 2015 no matter if the alternator is putting out power or not, one end of the wire is connected to a battery. If the wire shorts the alt can stop putting out power all it wants but you will still have a dead short. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Bump4life Posted October 8, 2015 Report Posted October 8, 2015 Presuming you're talking about the alt to under the hood batt connection, and not a long run to the amp(s), then I agree with hdorre. Just a run of 1/0 from alt to batt, no fuse is what I do. The odds of you creating enough current to damage that short of a run is it won't happen. i think of fusing that wire as more of a fuse for the battery's sake, not so much for the alternator. i don't fuse that lead, though, because it's shorter and safer if wisely run. The alternator SHOULD detect the short and shut down, as for the battery at the other end...not so much. not true. alternators do not shut down. the burn down the rectifier if there is a short. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
Wehan Posted October 11, 2015 Report Posted October 11, 2015 Presuming you're talking about the alt to under the hood batt connection, and not a long run to the amp(s), then I agree with hdorre. Just a run of 1/0 from alt to batt, no fuse is what I do. The odds of you creating enough current to damage that short of a run is it won't happen. i think of fusing that wire as more of a fuse for the battery's sake, not so much for the alternator. i don't fuse that lead, though, because it's shorter and safer if wisely run. The alternator SHOULD detect the short and shut down, as for the battery at the other end...not so much. not true. alternators do not shut down. the burn down the rectifier if there is a short. True for some then, The Denso Alternator on my 93 Jeep Wrangler shut down when I foolishly routed a 10ga wire into the cab with no fuse (I was young and retarded) melted on the cylinder head and shorted, in fact that's the only reason I knew it happened because it was at night and all my lights dimmed and the volt gauge dropped from 14.5 to 12v. I pulled over and saw the wire smoking so I whipped out my leatherman and cut it at the battery. I had to shut down the Jeep and start it again to get the volt meter to go back to normal.
