feathered1iron Posted October 8, 2015 Report Posted October 8, 2015 I am currently using a 200a fuse on stock alt, will I need to use a larger a fuse for the 370a mechman alt I am assuming? Current Setup: Mechman 370a Alt 4 pin DC Triple Alt Bracket XS3400 Battery 4 Ampere 6.5 components 4 tweets Ampere 150.4 way Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms DG Roll Pan LED License Plate Lights
hdorre Posted October 8, 2015 Report Posted October 8, 2015 i wouldnt even bother fusing the alt On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
reedal Posted October 8, 2015 Report Posted October 8, 2015 Presuming you're talking about the alt to under the hood batt connection, and not a long run to the amp(s), then I agree with hdorre. Just a run of 1/0 from alt to batt, no fuse is what I do. The odds of you creating enough current to damage that short of a run is it won't happen. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
MrSkippyJ Posted October 8, 2015 Report Posted October 8, 2015 Snafu would disagree with both of you about fusing the Alt to battery wire. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
reedal Posted October 8, 2015 Report Posted October 8, 2015 Yes he would. As do many others. I personally don't feel that it is necessary. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Bump4life Posted October 8, 2015 Report Posted October 8, 2015 its only necessary if wire is going to break or get pinched and short out Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
MrSkippyJ Posted October 8, 2015 Report Posted October 8, 2015 I'm just not a fan of having live wires without fuses. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
hoit Posted October 8, 2015 Report Posted October 8, 2015 ^I agree. Unlikely, but possible. I'd rather have fuses than fire extinguisher. To each their own though! 2007 Chevy Aveo Ls sedan 2 Sundown Xv2 on scv4k @ .5 ohm 2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm Big Three, Three runs 1/0 power from front to back, 1 ground front to back Two runs ground from rear bank to chassis XS power d3100 upfront, 3 Odyssey 2150s in bank Singer 220 amp alt
aps01 Posted October 8, 2015 Report Posted October 8, 2015 you can run 2 runs of 0/1 awg wire and use 300 amp fuses on them so problem solved! '92 toy rolla EE90/AE92 1.3lt 12 x 8inch beyma (mids) 6 x beyma CP21-F tweeters(highs) 4 x 15 SPL Dynamics SPL380 D2(walled) 2 x ESX Vision 2500.2(mids,highs) 1 x SPL Dynamics D9-XS(subs) 4 x stinger SPV70 + 5 X SVR platinum 3500P batts 157.2 official on db drag comp-157.3 on same comp but eliminated...still a work in progress... Team Hxomania Trikala http://www.stevemeadedesigns.com/board/topic/156885-lil-noisy-toy-rolla/
SLYentist Posted October 8, 2015 Report Posted October 8, 2015 Presuming you're talking about the alt to under the hood batt connection, and not a long run to the amp(s), then I agree with hdorre. Just a run of 1/0 from alt to batt, no fuse is what I do. The odds of you creating enough current to damage that short of a run is it won't happen. i think of fusing that wire as more of a fuse for the battery's sake, not so much for the alternator. i don't fuse that lead, though, because it's shorter and safer if wisely run. Cables and wires almost never fail; the terminations do.
