more electrical issues :(
bass amp is just fine but the 125.4 keeps cutting off randomly ill be listening to the radio n then the words just cut out that dam amp just loses power if I cut the whole system off and then turn it back on it gets power on again and is just fine what d heeellll is going on I checked the remote wire its good n tight power n ground are fine so any suggestions thanks for any help and yes I expect the smart azzz people to chime in but that's cool I just wanna get this resolved
and that would have to mean one my batterys takin a dump right ive upgraded my electrical system as well and have volt meter so I know I never drop under 13.5v
How is your remote wire ran to your amplifiers? Is it just the remote from the head unit powering both amplifiers? Or did you use a separate switched source for one/both?
see that's the problem I believe both from the head unit but I really cant say without ripping all that shit out like I think im fixing to do and look at it all I didn't install it I... well long story short I don't know how any of this is wired up and had nothing but issues sinse I got it back and that place I got it done is to dam far away for me to take it back plus it wasn't a shop anyway just a guy I know with all that stupid stuff I just said can you tell me anything thanks again im trying to get ahold of that guy now and have been but no luck I might have to start over with the wiring
Ok. Figure out how your remote wires are ran, if they're both coming from the same source, disconnect the remote wire from your sub amplifier, leave it plugged into the 4-channel, and see if it still cuts off at the volume level it usually does
What amplifier are you using? Are you running 1 remote wire for multiple amps?
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
