CleanSierra Posted November 26, 2015 Report Posted November 26, 2015 The subs have a reasonable EBP of about 68 on the 2 ohm model and about exact same on 2 ohm model. It seems really well suited for sealed or ported. This might turn into a bandpass 4th order thread... Im not the one you want to try to troll. Just a fyi for you.
Massivespl Posted November 26, 2015 Report Posted November 26, 2015 Ported or 4th order for xfls. We have done both with 15" xfls with good results c-pillar flat wall 157.11db on music 2 crossfire 8k 4 NSV3 18s 4 crescendo 10s 4 Rockford pro 6.5s Quad excessive amperage 350alts 4 juicebox 3100s
Anand Sayroo Posted December 2, 2015 Author Report Posted December 2, 2015 4 cubes^^ I want it to hit lows as well.. Don't you think 4 cubes a little on the small side? Not really, that's a reasonable size for four 12" subs. I haven't looked up the specs on the subs yet to see what they will like. With a sealed box, the bigger you make it, the more low end bass you will get, but you have to keep your cone excursion under control. Make the box too big and you will be reconing your subs in no time. What kind of space do you have to work with? Keep in mind that at some point getting as loud as possible and having good sound quality become contradictory goals. You can get a bit of both to a point, but after that you have to sacrifice in one area to gain in the other. Its the trunk of an 04 quest. I have tons of space, i have about 12-13 cubes of air space that I can play with.
Triticum Agricolam Posted December 2, 2015 Report Posted December 2, 2015 Since you have the space, my recommendation would be to use a well-designed ported box. A good ported box is almost always the most efficient use of space, and if designed correctly, it can have excellent sound quality. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
CleanSierra Posted December 2, 2015 Report Posted December 2, 2015 I would do roughly an 8 cube ported enclosure for 4 of those subs. Im not the one you want to try to troll. Just a fyi for you.
Anand Sayroo Posted December 5, 2015 Author Report Posted December 5, 2015 Since you have the space, my recommendation would be to use a well-designed ported box. A good ported box is almost always the most efficient use of space, and if designed correctly, it can have excellent sound quality. I would do roughly an 8 cube ported enclosure for 4 of those subs. I had two HD 12s in a 9 cube t-line and they sounded amazing ! So I'm just trying to recapture that sound again just louder
Anand Sayroo Posted December 5, 2015 Author Report Posted December 5, 2015 Any ideas on an enclosure design ?
Triticum Agricolam Posted December 5, 2015 Report Posted December 5, 2015 Any ideas on an enclosure design ? What are the dimensions of your space? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Anand Sayroo Posted December 6, 2015 Author Report Posted December 6, 2015 Any ideas on an enclosure design ? What are the dimensions of your space? width left to right : 41 inches length front to back : 19 inches height : 58 inches ( can go higher but rather not )
Joe X Posted December 6, 2015 Report Posted December 6, 2015 OP a couple of questions, 1 What tuning you had for the t-line? 2 only 19" deep? It would seem to me that you should model the tline and base your ported design on that.
