silk tweeters on a budget that get loud to replace 4 crescendo rts-1s.
Rich Schenk
tweeters our mounted in a pillars low aimed at windshield. need help deciding on some tweeters that will replace 4 crescendo rts-1s have them run active off of a pioneer 80prs and powered off of a skar sk 85.4 85 x 4 @ 4 ohms or 125 x 4 @ 2 ohms. now my question is since crescendo doesn't make these tweeters anymore and not sure when the new models will come out. track down more rts-1s to replace the messed up ones or just change everything out since i never permanently mounted anything. was thinking these but not sure if they would get loud enough image dynamics xs28 4ohms 100 watts rms per tweeter ,200 rms per tweeter peak frequency range 900-25,00k (sensitivity 92 db).
or go with something like this but not sure if it would be loud enough and would have to figure out how to fiberglass this in
cdt HD 2 4 ohms rms? peak? frequency range 250-21,000k
or get 4 tweeters from madisound or parts express. sort of lost and dont want to spend more then $100
would like tweeters to be crossed to 2k or 1.5k if all possible. any help would be apreciated ty.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Why do you want them crossed as low as 2000 htz ??? That's very low, even for Sound Quality.
I would suggest no lower than 3000 htz ... and that's pushing it.
Crossing your tweeters that low is most likely why you blew them.
The frequency response and crossover point you should use are not one in the same.
Rule of thumb for tweeter crossover point is no less than double fs.
So what what tweeters would u guys suggest?
Well, I would suggest buying a pair of better built tweeters over a multiple cheaper setup any day.
As far as brands ... not my department brother.
I had them crossed at 3k and where playing fine for months as soon as I switched to sk85.4 only lasted a month or 2 with gain way down. I know I blew them cause not having crossover points set right. New to this active setup stuff. So what would u guys suggest for tweeters because the 2sets of rts-1s where keeping up with my sub stage fine.
If you want a tweeter that can be crossed low and can get loud you're going to want a large format tweeter such as this.
https://www.parts-express.com/morel-cat-378-1-1-8-soft-dome-horn-tweeter--277-084
With a fs of 700hz you could potentially cross it at 1400hz.
That being said I still would not cross it that low because you have other drivers that should be used to cover that range.
I would still cross them at 3k or higher.
Just by reading this post would make me think the amplifier is the problem being you stated that they were crossed over at 3000 htz.
Sorry, just my observation.
  • Who's Online   0 Members, 0 Anonymous, 836 Guests (See full list)
