Man, you are killing it with excellent craftsmanship!
I'm curious to know, when building a series tuned BP6, the rear chamber does not require the port area of a parallel tuned BP6? I'm thinking your rear chamber needs the port area of at least 2 of the 12" subs.
These seem to need very little port are. 6-8 in^2 per cube. Helps tune the rear low.
YouTube: https://www.youtube.com/user/JeepAndBass
Website: https://www.jeepandbass.com/
My Jeep: 157.3dB @26hz Drag Style 162.3dB @36Hz Outlaw 160.7db @35hz Headrest
My Honda: 155.4dB Drag Style 158.0db Outlaw
BR port area is not based on enclosure volume. BR port area is based on speaker displacement (Sd). A good rule of thumb for BR port area is 1/3 to 1/2 of the speaker diameter. Since you have six 12's, then your rear port area should equal 2 to three 12's. Looks like you could get away with using half the area of the front port for your rear port.
For lower tuning, you would have to make the rear port longer which would increase the total size of your rear chamber.
Did you model your BP6 in WinISD or Hornresp? Both simulators have port air speed calculators.If I remember correctly, WinISD states your ports air speed should be under 0.16 mach to prevent port noise.
Ran a little speaker wire and installed a few SMD terminal cups. Subs are being built and will be getting door panels going here soon.
30B4591C-D834-4599-9861-D492912F5271_zps
0CFE7ADC-CC78-46AE-9596-697A6F7307C8_zps
C057CF3A-82A1-4667-A603-37FAA0E16EEA_zps
279DD64B-7C82-44DF-A059-2F699F8D73C3_zps
Beautiful installation!
Holy shit, dat SMD gear!  huge piece on bottom.  =()
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
  • 3 weeks later...
D3082FD3-764E-4DEC-9F45-DB17EA58FA12_zps
A100002D-D395-4B41-B197-A62372CC6722_zps
Little play time just to hear them. Very impressed! Super loud and clear!
9ACCE7FD-B755-4109-850E-EA10889A48C3_zps
0FB0661B-266B-4C16-ABB6-09908B207F7F_zps
