Best 5.25" component set under $150
bmwking
As the title says. It's time to upgrade the mids and highs in my bimmer. I want to utilize stock locations and sizes. I listen to everything from decaf to black metal and everything in between. Sub stage is 2 XFL1244s in an AB spec SPL box run by a ph4000md, mids and highs will be run by an eXcelon 542. HU is a CDE-HD149BT. Thanks in advance!
Lots good options for 5.25 out there.just go to ebay and find what best suits you.everybody has there own opinion. With that hu I believe you can run active .not sure on your amp if its a four or two channel..do you like alot of midbass? Do you like loud? I seen some jbl,realm,pionner, that look pretty good.really depending what you want.everybody ears hear different.
the amp is a 4 channel. i like there to be a smooth transition from sub to mid, but i know there are limitations to a 5.25 as opposed to say an 8. i like loud, and clear.
Only way for you to know is listing to them.hell you can get some morel maximo around that price you have.and proper deadning is the key..
luckily the factory mounting is in a sealed enclosure in the door panel.
well after a little more research it seems going custom is going to be my best option as i have 3 speakers in each door:
5.25" woofer
2" mid range
3/4" tweet
other than madisound, where else should i be looking? also what should i look for when sourcing a crossover?
  • Who's Online   0 Members, 0 Anonymous, 1090 Guests (See full list)
