pioneerforlife Posted November 24, 2015 Report Posted November 24, 2015 so i have heard some people say it is not the best idea to run maxwell caps and lithium batts together. just trying to gather more info on why this is. thanks. 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
kalilac619 Posted November 24, 2015 Report Posted November 24, 2015 In for info as I'm debating adding caps with my existing lithium batt 2000 Suburban 6 runs of 2/0 12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door 475ah of yin long LTOs Triple 370 Amp Autotech Alts mids amps 2 Crescendo Skyway 3ks compreesion horn amp crossfire 800.4 Tweet amp Crossfire 2000.4 sub amp: 4 Crossfire XT 8ks Subs: 8 18 in Crossfires in a 4th order Best Scores at events… 163.5@38hz DBdrag sealed on the dash… 164.3 outlaw…162.9 Meca headrest
IH8PunkRok Posted November 24, 2015 Report Posted November 24, 2015 Here is my take on caps and batteries together Batteries sit at a much lower voltage when not being charged than caps. If you charge a battery at 14.8 and remove the charging source it falls to say 13. Capacitors in the same situation will remain at 14.8 for some time. Since electricity is all about balance, every time you turn off the car the caps begin charging the battery with everything they can muster until the voltages equalize. Essentially the caps will charge the batteries too hard and lead to their demise. If I understand right lithium is especially sensitive to this rapid overcharging -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
ToNasty Posted November 24, 2015 Report Posted November 24, 2015 Correct me if I'm wrong but I think you have it backwards. I always thought caps discharged faster while resting ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
IH8PunkRok Posted November 24, 2015 Report Posted November 24, 2015 Correct me if I'm wrong but I think you have it backwards. I always thought caps discharged faster while restingKind ofWe have a bank that had been sitting for 2 years which still rests at 8.5 volts. A battery in the same situation would be resting higher, I'm sure. But I'm talking immediately off of charge a battery jumps back down around 2 volts, caps very slowly walk down -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
pioneerforlife Posted November 24, 2015 Author Report Posted November 24, 2015 You can run caps and regular agm batts together no problem. I'm wondering about lithiums 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
pioneerforlife Posted November 24, 2015 Author Report Posted November 24, 2015 so just talked to kevin with Juice Box Batteries and he said you can run caps with a lithium 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
420c Posted November 24, 2015 Report Posted November 24, 2015 Mostly its a safety issue due the massive damage that could be done to you or your vehicle if there is a failure from either one and if you combine them and theres a failure your pretty much dead
420c Posted November 24, 2015 Report Posted November 24, 2015 Probably not the best for daily but theres always a risk in anything you do.
pioneerforlife Posted November 24, 2015 Author Report Posted November 24, 2015 Mostly its a safety issue due the massive damage that could be done to you or your vehicle if there is a failure from either one and if you combine them and theres a failure your pretty much dead With caps as long as you don't overcharge them you wont have issues. Pretty much same with the lithium. As long as you don't rub it too low or charge to high you should be fine. Plus the chemical makeup of the lithiums used In car audio is more stable. I was just trying to figure out if the caps could somehow damage the battery 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
