ok so im interested in getting 2 sundown 1500s and strapping them but i only have one woofer. its dual 2 ohms and would like to strap at 2 or 1 and not 4.
any way to do this without buying another woofer?
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
*nvm*
Edited by emat19876
just do 1 amp per coil
NOO
dont do that.....Just parellel the coils to 1 ohm and strap that to the two amps....each amp will do about 1800 or so watts rms at .5 Ohm at each amp
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
1998 Cadillac Catera
SPLMAX CUP 2008 Fourth Place Overall
NOO
so do i put the positive wire from the woofer to the positive on one amp, and the negative to the negative on the second amp?
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
lol nevermind, im buying a Z1
:D
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
so you changed your mind in four minutes ....
2007 Toyota FJ Cruiser Voo Doo Blue
my upgrades and "build" thread.
My Kulicki Box Build
-Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars
-Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash )
-JL Audio 2 way Component set XR650CSi
- Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box.
-Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio
-All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0,
-270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum-
-2 Powermaster D680 Powercells in back
FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz.
Shoehorn, BFH, forklift,duct tape and some zip ties
first parallel the two coils on your dual vc woofer...then you will have two leads from the woofer, one + and one - with the sundowns just "bridge" the negative terminals of the amps to each other, and connect the + wire of the speaker to the + terminal on the master amp. then the - speaker wire to the + on the slave amp. be sure to have the RCA's ret right for straping amps
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
