Best way to brace a box?
Goblenator
i planned on using the tic-tac-toe board window brace using .75 in MDF. Is 1in big enough or do i need to move up to 2in? It will be a monolithic piece as well.
What do you mean by 1in or 2in?
I used this bracing on my enclosure I just built, and I'd recommend it. My enclosure is wide, so there was a lot that was unbraced, and just tapping on the front panel was a very hollow sound. Made that brace and slid it in snug, tapped in the center of each respective side of the brace and no more hollow sound.
if you were to assemble it in pieces would you use 1in or 2in wide wood?
Im going to go for 2in.
That's what I thought but wanted to be sure. I made mine ~1inch out of 3/4" birch ply
i assume monolithic pieces are better than assembling them with strips of pine
How do you guys cut perfect squares that small in a piece of .75 mdf?
Router? Or jigsaw?
Heres what I did
D7DBEFCB-2FF7-4CE8-8245-647FE931BC2B_zps
50D4662A-7057-47BC-BDF5-8C89452D1BE5_zps
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Router? Or jigsaw?
I used a jigsaw. Drilled a hole in each corner of each square I wanted to cut, then inserted the jigsaw blade and cut away. Then do round overs on the edges if you want.
Router? Or jigsaw?
exactly what i visioned. Wasnt sure if there was a better way. probably is but a jigsaw works.
Router? Or jigsaw?
Jigsaw is the fastest, they don't have to be perfect, just reasonably close.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 2583 Guests (See full list)
