Genesis coupe drag car build log
well i stopped by the machine shop on the way home from work and i was quoted 75 to clean up the block and all internals and a hone if needed im also going to have the heads cleaned and decked but the decking will cost more
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
i absolutely plan to deck the heads because they are aluminum the block is iron and it should be fine with a good cleaning with a razorblade
but on the other hand if the machine shop sees anything then we will address issues then
Should be fine? At least have it checked with a micrometer, or whatever machine shops use.
of course
why are you wasting your time with stock 317 heads? Step up to some mast or afr heads
Used to have a loud truck
why do you have to come in here and bash my build with your every post... the heads you listed are like 2500-4k a set assembled and i can get well over 300cfm out of these castings especially after i port them im trying to save some money by useing stock parts to get my car running sooner and then do upgrades as i go... just like with sound systems you werent running 15k watts in your first system you start small and work your way up
Those stock heads should support 500-600hp with minor work done to them with no issues, no reason to swap them out at all.
Im not bashing, trust me you would know if I was. My heads were $3500 but thats including .700" springs and flow damn near 400cfm, its cheaper to buy the good shit the first time than to waste money on porting the stock heads only to swap them out later.
No, I didn't start out with 15k watts but I didnt say I was going to do 170db either :good:
