Fibreglass hollow spheres
You will most likely have to do finish work. It's gonna be basically impossible to get a smooth outter layer without a nice mould. Body filler and sand paper will be your friend and enemy. The other thing I've used thanks to a friend for tweeter pods is a wooden sphere to like top railings or something like that. Forstener bit it. Drill an intersecting hole and lamp post thread it so you can run wire thru it.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
get a Styrofoam ball from a crafts store and cover with as many layers of fiberglass needed. let cure then cut/drill a hole the size of the driver needed. use acetone to dissolve the Styrofoam ball. your left with a spherical "pod"
X2
Looking like I will have to settle for a 'near' uniform exterior... Which is ok, but I'm wondering if anyone here has any information on the "rolling ball method" for making macrosphere balls and if it could be scaled up to make larger balls... I cannot find any information with a web search as well as any videos showing the process how they are made...
Thanks for your help
http://www.douglasandsturgess.com/product/8-0429.html
Something like that work for you?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
how important is it, that the spheres must be made out of fiberglass?
Bet you could get some ABS plastic spheres made with a 3d printer a lot easier
Settled on the idea of using a polystyrene ball and adding fibreglass and not worried about leaving it in the sphere... Main thing is that the (semi)hollow sphere is made of fibreglass or even Kevlar... Aiming for the strongest and hopefully can be produced with reasonably good speed.
The idea of the 'rolling ball method' for making macrospheres sounds appealing only if it can be done in larger sizes... Still can't find out how it's produced though.
How strong are we talking? Because if you're wanting aramid strong I'll tell you know they will be expensive as hell and very time consuming to make. At that point I would recommend having a mold machined.
