jessdabest77 Posted December 9, 2015 Author Report Posted December 9, 2015 Thanks guys I do not want to mess anything up. I have rev up and it still does nothing.
Miguels Posted December 9, 2015 Report Posted December 9, 2015 Not wired correctly my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
jessdabest77 Posted December 9, 2015 Author Report Posted December 9, 2015 That would suck cus its hard to get to
reedal Posted December 9, 2015 Report Posted December 9, 2015 Did you make sure that the wire that connects the battery TO the alternator is properly connected to each....? Sometimes in our excitement of playing with new toys we as humans forget steps in a haste to start playing. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
reedal Posted December 9, 2015 Report Posted December 9, 2015 Are you using the stock wiring or did you add to it? Have you measured voltage directly on the alt's connector post to see what it's reading there? And, did you use the stock wiring harness? Or did you have to have an adapter harness for the alt made? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
reedal Posted December 10, 2015 Report Posted December 10, 2015 And the answer to the rest of the questions...? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Lakeshow94 Posted December 10, 2015 Report Posted December 10, 2015 I added on to it If you want help fixing the issue you should probably answer with more than "i added on to it".................. 1999 Lexus GS 300 Pioneer DEH-80PRS Singer 240 Amp (Will be installed later) Northstar Group 31 & 24 Sundown SCV-4000 Rockford T400-4 2 12" CT Sound Meso CT Sounds 6.5 Meso Components CT Sounds Tropo 6.5
jessdabest77 Posted December 10, 2015 Author Report Posted December 10, 2015 I apologize, i added 1/0 sky high ofc to power and ground
