jessdabest77 Posted December 9, 2015 Report Posted December 9, 2015 The car is a 1991 Acura Integra hatchback and I have installed a Singer 270 amp alternator and with the car on I get 12.02 volts and withe car of I get 13.04 volts. Why is that and I have tested the battery and alternator and both are good,any answer's?
Lakeshow94 Posted December 9, 2015 Report Posted December 9, 2015 Could be a few different issues. Belt slip due to too big of a belt. Belt slit due to not enough tension on an accurate belt. Low idle. Are you seeing those low numbers at all times or just idle? Do you hear a squeak from the belt? Do you see any residue coming off the belt? 1999 Lexus GS 300 Pioneer DEH-80PRS Singer 240 Amp (Will be installed later) Northstar Group 31 & 24 Sundown SCV-4000 Rockford T400-4 2 12" CT Sound Meso CT Sounds 6.5 Meso Components CT Sounds Tropo 6.5
Lakeshow94 Posted December 9, 2015 Report Posted December 9, 2015 With the car off you are measuring the voltage of your battery itself, with the car on you are measuring alternator output voltage 1999 Lexus GS 300 Pioneer DEH-80PRS Singer 240 Amp (Will be installed later) Northstar Group 31 & 24 Sundown SCV-4000 Rockford T400-4 2 12" CT Sound Meso CT Sounds 6.5 Meso Components CT Sounds Tropo 6.5
reedal Posted December 9, 2015 Report Posted December 9, 2015 Do you have any warning lights on? (Service engine, battery, etc?) If you're sitting at 12 with the car on, your alt isn't on. How are you measuring this voltage? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
jessdabest77 Posted December 9, 2015 Author Report Posted December 9, 2015 Ok,with the car of at the battery I get 12.8 volts,and with the car on at the battery I get 12.02 volts. The belt is tight,no rip's or squeks,and no service lights on in the car. I have heard in these cars you have to cut the alternator wire from the ECU,but don't know which wire and if that's even true.
Bump4life Posted December 9, 2015 Report Posted December 9, 2015 the alternator is off or not working.\ the load of the car running is bringing the voltage down. if you rev up does voltage change at all? Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
Lakeshow94 Posted December 9, 2015 Report Posted December 9, 2015 Ok,with the car of at the battery I get 12.8 volts,and with the car on at the battery I get 12.02 volts. The belt is tight,no rip's or squeks,and no service lights on in the car. I have heard in these cars you have to cut the alternator wire from the ECU,but don't know which wire and if that's even true. I wouldn't start cutting. Maybe someone with the same vehicle will chime in. Email singer as well. I had an issue with my 98 Camry and he explained/fixed my issue. If its a common issue and not a different issue singer will probably know what's wrong. 1999 Lexus GS 300 Pioneer DEH-80PRS Singer 240 Amp (Will be installed later) Northstar Group 31 & 24 Sundown SCV-4000 Rockford T400-4 2 12" CT Sound Meso CT Sounds 6.5 Meso Components CT Sounds Tropo 6.5
Lakeshow94 Posted December 9, 2015 Report Posted December 9, 2015 You try putting stock back in? 1999 Lexus GS 300 Pioneer DEH-80PRS Singer 240 Amp (Will be installed later) Northstar Group 31 & 24 Sundown SCV-4000 Rockford T400-4 2 12" CT Sound Meso CT Sounds 6.5 Meso Components CT Sounds Tropo 6.5
Kyblack76 Posted December 9, 2015 Report Posted December 9, 2015 the alternator is off or not working.\ the load of the car running is bringing the voltage down. if you rev up does voltage change at all? This. Your alt is NOT turning on at all. You dont have the sense wire, or turn on wire hooked up correctly. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Rich Schenk Posted December 9, 2015 Report Posted December 9, 2015 I would double check your install to make sure all your wires our hooked up to alternator. Call or email singer he will get you right. On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
