thebluesbox Posted December 20, 2015 Report Posted December 20, 2015 We are of the minority I know, but we are out there. Truck guys, that want a little bump in thier pickup with ext cab and are limited in space. I started out with two 10's and a autotek MM 4000.1 that's 1000 x 1 @ 4 ohms. The two 10s are 500 watts rms a piece. Sounds pretty darn good and hits pretty good for 10s. But I couldn't help but wonder what I would have got if I had gone with 2x12's, so I ordered two 12s and I'm going to try them out. I'm already handy capped because of the limited space I have to work with on an under seat box, but I am going to try it and see if it's better or worse. The amp can't do 2000 @ 2 ohms, so I'm going with 2 ohms this time and subs can handle 1000 watts each. Any of you run 12's in an under seat enclosure? FYI I have a silverado 2500hd.
Triticum Agricolam Posted December 20, 2015 Report Posted December 20, 2015 What subs did you get and how much internal volume does your box have? Bass takes space, so you are always going to have a tough time with underseat boxes. Raising the seat a few inches can open up a lot of opportunities. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
thebluesbox Posted December 20, 2015 Author Report Posted December 20, 2015 I had a tuff time with my choice of subs because of wattage I need and the mounting depth I'm working with so I went with power acoustic BAMF. I have 1 cft for each sub which I know is really minimal.
miniSPLlancer Posted December 20, 2015 Report Posted December 20, 2015 Buddy of mine has 4 DD 8's on an M3b and I'll tell you right now that stuff bangs. I was shocked at how beast they were. All under the back seat of his truck. Chevy quad cab I believe. 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals
thebluesbox Posted December 20, 2015 Author Report Posted December 20, 2015 Well the two 10's I have in there now with .95 cubic feet each are pounding real good, and I like the sound. I just want to see what a couple 12's at lower ohms and higher watts will do. Right now the 10's are at 4 ohm which is making the amp push half its power at 1000 watts.
SGTSKIP Posted December 20, 2015 Report Posted December 20, 2015 I put 4 10's , JL Audio's W3s in my dads truck..... Glassed it all the way. 2 Punch 500s. Sealed. it rocks Does this smell funny to you? Its your sister
Hugh G. Rection Posted December 21, 2015 Report Posted December 21, 2015 When i do extended cabs, the only way i do them is remove the bottom half of the back seat, build the box, put seat foam on top of the box and upholster it. Way more space to work with. If someone just wants something under the seat, i turn the work down. I have a certain standard for my work, and cookie cutter bullshit has no appeal to me, thats why i quit working in shops. Owner of BigAss Ports
Cwallaker Posted January 27, 2016 Report Posted January 27, 2016 I'm running 2 12's in 1.50 cu ft each under the back seat . I lifted the seat using 2×3 steel tubing under each of the feet . I raised the brackets that the back slides on up 3 in and, welded them in place. It bangs pretty good but...., like most ,I want more!
Keith77 Posted January 27, 2016 Report Posted January 27, 2016 Someone say under seat boxes? Edit: not my work... Kyle Golden is the master fab.. Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born. My penis is bigger than your penis I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
SGTSKIP Posted January 27, 2016 Report Posted January 27, 2016 Wow, those look awesome Does this smell funny to you? Its your sister
