Engine idle fluctuation with supercaps...
Anybody experience an engine idle fluctuation when using supercaps?
When I connect a bank of 500F in my car, my idle will fluctuate a couple hundred RPMs every couple of seconds.
It's not a big deal other then being annoying while sitting at a red light.
When driving (higher RPMs), it goes away.
When I remove one of the leads to the caps, the issue goes away. So it is the caps that are inducing it somehow.
I've tried two banks with the same results.
I thought it was the balancing modules but both my banks do the same thing.
I'll remove the modules and try again to see if that helps, but they're fine on a test bench with a power supply.
With a current clamp, I saw about 20A flowing in and out of the caps while the idle was fluctuating...
Ideas?
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
Like, as if your alt is being loaded down? I know that when i demo at idle, my RPMs drop about 100-150 RPMs
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Imagine tapping a heavy load to the cars electrical system every two seconds or so, repeatedly....
Like that .....
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
Yep, two XP3000's and a small D375.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
My truck does it too always thought it was my regulators
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Try this: with car parked and engine idling, turn on headlights, then turn your heater fan to full blast. Did the idle smooth out, or is it still bouncing?
Good suggestion.
Turning on the rear defrost (or similar load) smooths out the fluctuation.
Interesting....
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Find it if your vehicle has something like Bypass Air Control, or Idle Air Control. These are basically little valves that increase the engine rpm a tad to compensate for the added electrical load. They can get gummed up over time and need to be cleaned it even replaced.
What your engine is doing is Idle Hunting it sounds like. It sees an increase in current draw to top the caps off so it raises the idle a hair, but then the caps fill and the demand disappears, causing the idle to drop again.
  • Who's Online   1 Member, 0 Anonymous, 1355 Guests (See full list)
