Bayuk89 Posted December 23, 2015 Report Posted December 23, 2015 i just build a box for a 15" subwoofer tuned to 32hz, on my amp the dial sweeps from 15-55 hz on the SSF. I think i need the SSF to be around 30hz ? I have an idea where it is on the dial so i marked it there, then un plugged my sub and hooked up my DMM on a/c volts. Put in a 30 hz sine wave test tone and went from 55 hz on the SSF and tuned down till i saw a flucuation in voltage and i stopped there which looks close to 30 hz would be if it was marked. Being tuned at 32 do i need to set the filter lower than 30 ? This is my first ported box, thank you for ur help.
reedal Posted December 23, 2015 Report Posted December 23, 2015 The rule of thumb is it should be set no more than one half octave lower than tuning frequency. so half of 32 is 16, half is 8, so 32 minus 8 is 24. 24hz would be your setting going by that. I don't agree with that though, because depending on the response of your enclosure you might run into problems starting at 30hz or 28hz, etc. I keep mine turned off and just listen for unloading, then turn it down. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Bayuk89 Posted December 23, 2015 Author Report Posted December 23, 2015 Thank you, unloading is basiclly the subs "fluffing" with not much out put right ? I will turn my knob down to about 24 then and go from there. I just wish there was a set notch with all frequencys on my amp instead of a sweep dial from 15-55. I can only get a ball park idea where im at lol.
Tarball Posted December 23, 2015 Report Posted December 23, 2015 CC1 CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Tarball Posted December 23, 2015 Report Posted December 23, 2015 http://www.stevemeadedesigns.com/board/forum/236-smd-crossover-calibrator-cc-1-topics/ CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
reedal Posted December 23, 2015 Report Posted December 23, 2015 Unloading is when the subs are losing their mechanical control. I suppose "fluffing" could be used to describe the noise coming from it. As tarball suggested, the CC-1 is a tool to set filters where you want them. Just remember that even if you go by the "rule of thumb", that does not mean you won't have unloading issues, and you could still damage the sub playing high volume at those frequencies. Just keep an ear out for it, and turn the SSF up as you need in order to prevent damage. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Bayuk89 Posted December 23, 2015 Author Report Posted December 23, 2015 Thank you tarball and reedal i will keep an ear out for funky sounds and what not. Im running a budget build right now. I NEED to invest in better/proper testing tools. I only have a DMM and my ears to help me get close to where i think i shoukd be. When i save up money for my next build i will price in a hand held oscilioscope, dd-1 and such. Thanks again for the helpful input.
hdorre Posted December 23, 2015 Report Posted December 23, 2015 I dont use one No need, if you know your music, gear and install. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Bayuk89 Posted December 24, 2015 Author Report Posted December 24, 2015 Thanks hdorre It's my first ported box I build and learning properly setting the SSF, over time my experience will grow and it will become second nature like how u do it.
CleanSierra Posted December 24, 2015 Report Posted December 24, 2015 I don't set mine at all. My box mechanically controls my roll off. I have an SMD CC-1 for setting the SSF though. Im not the one you want to try to troll. Just a fyi for you.
