Rockville M-4 At .5 ohm (no joke)
ShadeTreeMechanic
Which will be part of my next thread of the box build.
HDS315
Pioneer 80PRS
are you going to run different size subs?
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
Yes tuned as in you can change the tuning of it. Thanks for the great discussion like a true conversation you never really know where it is going until it gets there.
And now back to the M-4.
4 15s with M-4 on left.
what kid of truck is that? it looks like a four door bronco
Yes it is a 91 F350 Bronco 4 door Centurion conversion.
Pioneer 80PRS
WTF is a 4 door f350 bronco, I am confused! I also want one!
It's a f350 that was converted into a suv by centurion.
So a 4 door bronco.
Yes, the plan is to have the 4 10s with the HDS315s. 4 10s on two M-4 linked. HDS315s on the 4001D. The 4 10s wouldnt fit with the 4 15s so i had to conserve space with 2 HDS315s. The Pyle setup on the 4001D had awsome kick drums that would move your hair and the 15s gave it the digs that the 10s couldnt do. I dont have a picture of the 4 10s by themselves as they really needed the backup of the 15s and it wasnt long before i took them out. All on the same 4001D parallel on 15s and series parallel on 10s so the 15s got most of the power.
Pioneer 80PRS
The front of the truck is F350 crew cab 460 V8 and 8 lug rims. The back is standard bronco including the frame section that was grafted so the floor would be the correct height. I will try to find a picture of the whole thing. Check us out at fourdoorbroncos.com
Here it is with my 1976 Case 990.
Pioneer 80PRS
You dont have the different size subs playing the same frequencies, do you?
No dont have to. But i can get all of the bass. Not just the lows not just the kick i want it all. Its like running seperates but for the bass.15s would be crossed over 50hz and down and 10s 50hz and up to about 150Hz ideally. The Fb on the 10s is 60hz and the Fb on the 15s is 59hz. They sound different enough on the same amp to have a good effect but biamped bass is what i like. 10s on two M-4 linked and 15s on 4001D. Some people think i am a little different than the rest on alot of things.....
Pioneer 80PRS
