amp clamping accuracy ?
Bayuk89
I dont have an amp dyno but i heard another way to get a general idea how much ur amp is putting out is to use an amp clamp on A/C volts and put that around the positive side of ur sub wires then use ur DMM on A/C volts and hook them up along with ur sub wire input. Play test tones at 30-60 hz at max clean volume and find which hz ur amp puts out the most power. Times the volts by amps and thats roughtly what ur amp is putting out in watts form. Is this accurate or did i miss something ?
That method doesnt account for phase angle, and something else that nobody gives a shit about. Forgetting the name.... But expect an amp dyno to read 10-20% less than clamped numbers.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
pretty much. clamping will give you a number, it will be half way close. Close enough for most people. Just dont take it as gospel.
clamping is VA (voltamps) which is not Watts.
Ok thanks guys, ive seen alot of people use this method on youtube and they seemed like average joes like myself. I figured i would ask more knowledgable people on how accurate it is, thank you :) what do u guys think about the steve meade AMM 1 ? Its the hand held amp dyno, seems to be the same concept as using the ac amp clamp and ac volt meter......
Its a LOOOOOOOT of tool for the money. Its probably going to be my next SMD purchase in fact.
LMFAO so true
:blush:
I have one, I like it. I don't use it a ton, but when I do it tells me info that there is no other way to get for a reasonable price. I won't be getting rid of it any time soon.
Its probably not a tool that going to be worth the money for everyone, but if you like to tweak with things and experiment a lot, its very useful.
Builds:
No it measures more like the amp dyno. except I think it reads it with the amp connected to your cars power supply and your speakers so instead of telling you what the amps can do, it's telling you what exactly is happening in your car.
(I think anyway)
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
What skippy said, its a hand held amp dyno that u use when ur hooked up in ur vehical. Shows u what ur amp is really putting out with ur vehical electronics
So then the SMD handheld would have to be able to account for the phase shift between volts and amps because of the inductance in the voice coil? Im not sure how the handheld is hooked up compared to the DMM / clamp meter setup.
Pioneer 80PRS
  • Who's Online   0 Members, 0 Anonymous, 710 Guests (See full list)
