sendcliffmail Posted January 14, 2016 Author Report Posted January 14, 2016 kinda have no ideal what you mean? so just close this and go to an audio dealer to get real help?
3vil Posted January 14, 2016 Report Posted January 14, 2016 Dude are you spun or something? I'm getting a super methy vibe just reading what you type. Why would you do a c-pillar wall and remove the back seats? Do this: take your current box out of the truck, put the rear seat in, measure how much room you have. Your available space keeps changing. Measure how wide your cargo area is near the door and near the seats, how tall is it in the center and near the edges, how deep is it from tailgate to rear seat top/bottom. Nite do some geometry and figure out how much volume you might have. Now subtract for material thickness (walls, bracing, etc), let's subtract port volume and woofer displacement. Got a number?
sendcliffmail Posted January 14, 2016 Author Report Posted January 14, 2016 not at all. just trying to get a cutsheet.
3vil Posted January 14, 2016 Report Posted January 14, 2016 How is someone going to give you a cut sheet for a wall?!?
sendcliffmail Posted January 14, 2016 Author Report Posted January 14, 2016 ok i will get on this asap. my numbers change cause i check online for specs and then when i measure it, i get a totally different number. kinda dose seem strange i know. originally i wanted to just put a flatbox in the cargo area but i was told i don't have the room. to build a wall i thought you still have to build a port correct? i took my truck to a shop and they said give us $450 and we can build you a box easy to fit in the cargo area. so i decided that maybe i could build my own box. but as i can see, maybe that thought was way wrong. also i called two shops today and they both said just buy two prefab boxes and bolt them one on top of the other and make that the wall..had one guy tell me to buy 4 separate boxes and wire them together....i kinda thought that was wrong. and both claimed to have 20+ years experience. sooo getting so many different opinions has me very confused and mislead. no meth... just a very confused plan of attack here.
3vil Posted January 14, 2016 Report Posted January 14, 2016 also i called two shops today and they both said just buy two prefab boxes and bolt them one on top of the other and make that the wall......i kinda thought that was wrong. and both claimed to have 20+ years experience.I would not take my car to any audio shop that told me that when I asked for a wall. And yes a wall can be ported, or sealed, our 4th order, or a t-line, our even some 6th order double tapped horn if you really like math. Maybe you should do a bit nut research into what a walled vehicle is and what goes into building and tuning one. There are plenty of build threads here to get you started.But you're not just going to handed a cut sheet. A wall is a lot of work.
sendcliffmail Posted January 14, 2016 Author Report Posted January 14, 2016 i have no ideal what to do at this point since i apparently cant have anything in an suv. tomorrow im going to the audioshop who already quoted me and said this isn't going to be any sort of problem. ill let them handle it cause im the only person in my area with a system.
Hugh G. Rection Posted January 14, 2016 Report Posted January 14, 2016 you dont get it.. it can be better.. if you are using the excuse that you dont compete then why the 4 subs? 'Cause it looks cool. Owner of BigAss Ports
MrSkippyJ Posted January 14, 2016 Report Posted January 14, 2016 i have no ideal what to do at this point since i apparently cant have anything in an suv. tomorrow im going to the audioshop who already quoted me and said this isn't going to be any sort of problem. ill let them handle it cause im the only person in my area with a system. Why don't you take measurements? Nobody here can help you until you do this... F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
kirill007 Posted January 14, 2016 Report Posted January 14, 2016 i have no ideal what to do at this point since i apparently cant have anything in an suv. tomorrow im going to the audioshop who already quoted me and said this isn't going to be any sort of problem. ill let them handle it cause im the only person in my area with a system. Offcourse, one of those shops that always says that it all is going to work the way the customer wants it to work... i have no ideal what to do at this point since i apparently cant have anything in an suv. tomorrow im going to the audioshop who already quoted me and said this isn't going to be any sort of problem. ill let them handle it cause im the only person in my area with a system. Why don't you take measurements? Nobody here can help you until you do this... Because his car seems to change sizes in between measurements. (If I take a quick look at the different dimensions he posted.) Thinking is the root of all problems... You ALWAYS get what you pay for.
