Single Cab Truck Subs
max0r4axor
i'd throw a pair of Fi SSD 10's off a competitive 2-2.5k board like the Ampere Audio 2000.
fairly cheap. High quality, Efficient woofers, made in USA too. And Ampere... Texas FTW
but then again, get us some dimensions. Center console or behind the seat? I think you are working with like 18h, 52w, 8-10 deep at the bottom and like 6 deep at the top?
Gotta cut that width down some though, slot port out the end, leave atleast double the port width out the end between box and side of truck. If doing comps, sub on passenger side port out driver side.
Owner of BigAss Ports
oh yes, well that really depends on who he is competing with though. I've always liked how woofers driver side/port passenger side sounded.
he may be wider though, not exactly sure. I know he can squeeze 3.5-4ish cubes back there pretty easily.
Pretty much, if he can run each in about .9-1.1 cubes a piece on that power, he'll be golden. I ran my single in 1.2 cubes with 2 3" ports off a kicker 750 a lonnnggg time ago. The woofer loved it, and was very musical. Guy I sold it to, ran his SSD off a nendo 1500.1 and had to take some volume out for it.
Between the trim panels he's got 56" in width. If your port is side firing, you'll still have room toward the front of the side piece with clearance for it to breathe.
The dimensions are 56X14X6TDX9BD. TD is top depth and BD is bottom depth. I can't remember if 14" will fit under the top trim piece that runs along the back of the cab. It might be 13.5". Also, if you have a center console that folds up and down, you'll need to account for that in the enclosure. You'll have to make it dip down in the middle of the box to allow the console to go up and down properly.
For subs, the Fi SSD would be a good one. The Crossfire C7 is another. Sundown SA 10s or 12s would also fit very well. All you need is about 2 cubes sealed for these subs.
You don't have a bunch of room to do 2 12s ported properly but can easily do 10s in a ported enclosure.
My son's truck (build on my Sig) is similar to the way I plan to do mine ...
Good luck.
Im gonna bump this thread. Could some one make a dang cut sheet for this truck? I've got an 03 Silverado Reg Cab and I really really want a custom enclosure that fits in place perfect. I can start a new thread about this but I want some insight on this, cause I've been struglling for like over a year now with my prefab box sealed. and I hear a well made and tuned port built to specs box can have more SQ and still get dirty low and loud. Please help!
Like you guys are talking about all the fine points I've been observing in my truck. I want it to tuck under that back trim panel along the back wall. And still get maybe the 3.5 -4 cubes boom50cal above was talking about. Like this thread was perfect for me to stumble across. I've taken my own measurements and had a drawn design but doubt it was worth a crap at all. SO please, anything is greatly appreciated!
2003 Chevy Silverado Reg Cab. Rockford Fosgate 500a2 and Kicker ZR240 each on their own 12" Kicker Comp S. Small, but everyone's gotta start somewhere.
  • Who's Online   0 Members, 0 Anonymous, 1872 Guests (See full list)
