reedal Posted January 26, 2016 Report Share Posted January 26, 2016 Impedance is resistance. Resistance is impedance. Synonyms. Edit: and that's according to every circuitry class I've been in for every system that I own and work on. I haven't watch your video you posted yet, so I will keep an open mind. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
CleanSierra Posted January 26, 2016 Report Share Posted January 26, 2016 DC Resistance is not impedance. Maybe watch the video? I'm pretty sure D'Amore knows a thing or two about the difference between resistance and DCR. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
reedal Posted January 26, 2016 Report Share Posted January 26, 2016 When I'm home and not on the ship I will. I'm in no way implying he doesn't. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
_paralyzed_ Posted January 26, 2016 Report Share Posted January 26, 2016 DC Resistance is not impedance. Maybe watch the video? I'm pretty sure D'Amore knows a thing or two about the difference between resistance and DCR. At exactly 28:09 Tony says "The impedance or resistance". Tony himself uses resistance and impedance interchangeably. I think you misunderstood the point Tony was trying to make. His point was that a static measurement of the coil has little meaning, and since music is active all variables need to be accounted for. He wasn't in any way saying DCR is not impedance, he was saying DCR is but a fraction of the equation your system will actually see while playing. Yes you can measure the coils impedance with a DMM. I believe reedal was merely suggesting that he might have d1's instead of d2's and his ohm load to the amp may be lower than OP anticipated and the extra wattage may be over driving the sub. Link to comment Share on other sites More sharing options...
_paralyzed_ Posted January 26, 2016 Report Share Posted January 26, 2016 OP- can you post a vid? we can circle jerk around an answer for years, a video could significantly reduce that time. Link to comment Share on other sites More sharing options...
AA98hoe Posted January 26, 2016 Report Share Posted January 26, 2016 Power? Box? Freq TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted January 26, 2016 Report Share Posted January 26, 2016 DC Resistance is not impedance. Maybe watch the video? I'm pretty sure D'Amore knows a thing or two about the difference between resistance and DCR. At exactly 28:09 Tony says "The impedance or resistance". Tony himself uses resistance and impedance interchangeably.I think you misunderstood the point Tony was trying to make. His point was that a static measurement of the coil has little meaning, and since music is active all variables need to be accounted for. He wasn't in any way saying DCR is not impedance, he was saying DCR is but a fraction of the equation your system will actually see while playing. Yes you can measure the coils impedance with a DMM. I believe reedal was merely suggesting that he might have d1's instead of d2's and his ohm load to the amp may be lower than OP anticipated and the extra wattage may be over driving the sub. Your multi meter is measuring DC resistance, impedance applies to ac circuits. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
_paralyzed_ Posted January 26, 2016 Report Share Posted January 26, 2016 Bah! I wish I knew it all. I can't wrap my head around resistance and impedance both being measured in ohms, but not being equal.I'm going googling now! Link to comment Share on other sites More sharing options...
_paralyzed_ Posted January 26, 2016 Report Share Posted January 26, 2016 I kinda feel dumb now. At least I learned something. Always learning… and forgetting... Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted January 26, 2016 Report Share Posted January 26, 2016 Impedance is resistance. Resistance is impedance. Synonyms. Edit: and that's according to every circuitry class I've been in for every system that I own and work on. I haven't watch your video you posted yet, so I will keep an open mind. umm... no. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
