2012 Toyota 4Runner SQ+ build
Hello all, new guy here. I'm in the middle of an install on my 4Runner. I plan on competing in either IASCA rookie or novice and MECA street, both in SQ and possibly install.
As far as exterior mods there isn't too much. I did a small lift, some larger tires, new wheels, tinted windows, and a couple of other small things. The exterior is pretty much done.
For the system I am doing it on somewhat of a budget until I decide if I enjoy competing. If things work out I'll be doing some upgrades this time next year.
Here is the current plan:
Kenwood DDX372BT head unit with a pioneer camera
JBL MS-8 DSP
PPI P1000.1 amp
PPI P600.2 amp
PPI P900.4 amp
PPI P65c3 component set
PPI P.652 coax's
JL Audio 12w3v3 subs (3)
Wiring is a mix of Sky High and Soundqubed.
Head unit installed, all wires soldered with heat shrink.
A40451F0-0D49-4EA8-8098-A25DAF446013_zps
52D797B0-A4F9-419F-9161-0A23BAF9545E_zps
Next was building a pair of pillars to house the tweeters. This was my first attempt. They aren't perfect but over all I am very happy with them.
F39E48B2-747E-4012-AD7F-94275CF67F4C_zps
7BEB1675-0F11-4773-99B4-11EC8C98BF34_zps
575C89BF-DBBA-4B2E-9CDB-5F6F2C165A68_zps
7BF7A912-1F2B-475C-8AAB-1FA10CB43277_zps
The last part I have complete is the sub enclosure. This was my first time using a router and a brad gun. I'm not sure how I ever lived without either of them. They just make life so much better.
6D79439A-755B-4E09-9AD7-E7B8924700A2_zps
95D8B722-C6D8-4FC9-A555-1F6D391EB31F_zps
0F203652-7E10-4434-992F-EC51818110AA_zps
So that's all for now. I'll be back to work on it this weekend.
Looks good but I'd ditch thr coax. That 3 way set is nice though.
The coax's are for rear fill only. They should do fine for that.
I managed to make a little progress today.
First off, out with the old...
7BA82ECA-9364-4573-A914-853A688303CD_zps
Next it was time to do a little sound deadening. It was cold out so I ended up letting the car run the entire time while using a heat gun. Kind of off topic, but how often do you get to say "I burned my ass cheek on a heat gun today"?
Before.
4125538B-71B6-47F0-AF95-CE852F49887D_zps
After.
FF9C0003-3461-44B7-817A-5536ED52C71D_zps
CAE9A56F-31E3-46C8-99CD-4FD0C9F32A0F_zps
37371D37-C9CA-4807-A641-F1C0D1A7CDFB_zps
I put most of the interior back together. I'm working on some other things tomorrow so I didn't see any reason to finish it up.
0F99408A-4643-41C6-ADE8-79108F0224F5_zps
Progress is going slow but at least I'm making some.
First off was installing rivet nuts to give me something to bolt my new "floor" down.
2FAC2DA7-4AAA-491C-A34C-EDE28E4885BC_zps
3F7AAAB5-82C7-4181-AA16-2F1B2850D607_zps
If you look close you can see all six.
Next was mounting the sub box.
ECE35522-33DC-47D6-950A-2609B0F05B44_zps
This shows the wiring inside the box, nothing special.
CE6257F9-AB11-4C7E-82F9-D1D8E18C530B_zps
Here is the amp rack, has cutouts for wire and for four fans.
584C251A-1817-4CCA-A3F2-3A82F5FA6279_zps
Here is a picture of the back to show the t-nuts.
7B95E774-43E7-4D70-A952-8DE00C82D1FC_zps
Amp rack mounted. Unfortunately the security screws I purchased aren't long enough to mount the amps so I get to spend some more money. :D
0DDC3F7F-E68A-4361-847E-C2BD43961C13_zps
  • Who's Online   0 Members, 0 Anonymous, 1238 Guests (See full list)
