Robert North Posted February 5, 2016 Report Posted February 5, 2016 Setup: 2 alternators & 2 batteries -checked voltage readings. The same. Audio: 3 amps; 2 running the doors anf 1 on the subs. -both amps running mids and highs show 14.1-14.2 -sub amp shows 13.89 They are grounded to the same spot. I have bigger wire for the sub amp just havent upgraded just yet. All amps have 4ga. Upgrading sub amp to 1ga. Alternator whine (not real noticeable), turning volume to 0 hear a low pop. Any help or suggestuons would be great.
3vil Posted February 5, 2016 Report Posted February 5, 2016 are you hearing the noise from every amp, just the doors, just the subs?
hoit Posted February 5, 2016 Report Posted February 5, 2016 are the rca cables shielded? are they ran close to power runs? double check the ground for the receiver? ...is it really noticeable, or are you just that particular? ...just trying to help... 2007 Chevy Aveo Ls sedan 2 Sundown Xv2 on scv4k @ .5 ohm 2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm Big Three, Three runs 1/0 power from front to back, 1 ground front to back Two runs ground from rear bank to chassis XS power d3100 upfront, 3 Odyssey 2150s in bank Singer 220 amp alt
Jake Miles Mckeehan Posted February 5, 2016 Report Posted February 5, 2016 What you could do if you have rca leads is take some trigger wire (or any similar type of wire) and ground it with the rca around the ring. that might help, but what do i know.
ShadeTreeMechanic Posted February 5, 2016 Report Posted February 5, 2016 Check your RCA routing to make sure it is not near your power runs. Unplug RCAs from head unit to see if whine persists. Twisted pair RCAs are not as good as coaxial RCAs for noise rejection. Unplug RCAs from amps to test too. Pops when you turn volume to zero? Does it pop with any other buttons? I had a bad head unit that would pop even with the mute button. I returned it and got something different. Some Head units have an internal fuse on the RCA shield that can blow. Check the RCA ground to head unit ground with a meter. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Masterbasser Posted February 7, 2016 Report Posted February 7, 2016 I had alternator whine once and it was fixed by moving amps further from the magnet on subwoofer Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl
CleanSierra Posted February 7, 2016 Report Posted February 7, 2016 Even the cheapest RCAs nowadays, can be run on TOP of power runs without the slightest noise. My bet is an insufficient ground. Unplug your sub amp and see if it goes away. Im not the one you want to try to troll. Just a fyi for you.
CleanSierra Posted February 7, 2016 Report Posted February 7, 2016 Or your running a Pioneer head unit. If so, do the bare wire in a figure X on the RCA outputs on the back of the head unit. Im not the one you want to try to troll. Just a fyi for you.
Robert North Posted February 10, 2016 Author Report Posted February 10, 2016 Ok. Solve the problem. I replaced all my battery terminals up front. Cleaned the grounds. All the noise is gone. Thanx.
