Christopher Osterholm Posted February 11, 2016 Report Posted February 11, 2016 Got a question anyone know anything bout Banda Viking 5k amps I got a low batt fuse light and it won't play the subs any help please. The fuse looks good and check good continuity with a volt meter. I worked fine yesterday then to day subs won't play and low batt fuse light and clip short light is on
3vil Posted February 11, 2016 Report Posted February 11, 2016 Can you measure the voltage at the power terminals on the amp?
Ron36 Posted February 11, 2016 Report Posted February 11, 2016 Check your basics powers ,grounds , remotes , rca's , subs resistance .Something is not happy 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
Christopher Osterholm Posted February 11, 2016 Author Report Posted February 11, 2016 Yea everything checked good and all wires are connected nothing is touching. It has been playing since I bought it from someone and that was about 7 months ago never had a problem until now
Christopher Osterholm Posted February 11, 2016 Author Report Posted February 11, 2016 I also have a extra battery in the back that my mid amp is hooked up to and it works
3vil Posted February 11, 2016 Report Posted February 11, 2016 If it's going into some sort of protect mode then there is must likely a wiring issue. A visual inspection is a good start, but you should really start probing with a DMM to make sure everything is actually ok. I'd also triple check your ground from the amp to the body of the car, yours may have loosened up a little over the months and now the amp is unhappy. And you worded that a little weird, you have a 2nd battery that us correctly wired into your cars charging system, or you have a 2nd battery that just powers one amp?
Christopher Osterholm Posted February 11, 2016 Author Report Posted February 11, 2016 I have a second battery in the back that is hooked up in line with my battery under the hood the amps were connected to to the one in the back both monoblock and a 4 channel the 4 channel works fine I can hear words and music from my highs and mids but subs not working
Ron36 Posted February 11, 2016 Report Posted February 11, 2016 If all electrical is good with dmm , I've seen Rca's do some crazy shit maybe swap or if u got a spare amp laying around hook it up 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
DubNDodge Posted February 11, 2016 Report Posted February 11, 2016 Go to the banda facebook page and ask that. No one here runs banda really and will basically tell you that it's blown or will catch fire '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
hdorre Posted February 11, 2016 Report Posted February 11, 2016 Go to the banda facebook page and ask that. No one here runs banda really and will basically tell you that it's blown or will catch fire because it is. I ran a Viking, as have/do like 5 other team mates. These protection circuits are weird, and they get stuck in protect. Think of the "low batt/fuse" light as a protection indicator. Time to send her in. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
