Proper way to make trim panels?
so I'm trying to make a trim panel for my wall to seal it off and pretty it up a bit, but I'm not sure how to get the exact shape of my car. I've tried using tape to mold around the car then fiberglassing over the tape to hold the shape, but it didn't turn out all that well lol.
Cardboard
Cut to shape, tape/glue into place, fiber glass over that if you want, or use the shape of the cardboard to trace onto wood and cut that out for better durability than cardboard
Yep cardboard^
c-pillar flat wall 157.11db on music
2 crossfire 8k
4 NSV3 18s
4 crescendo 10s
4 Rockford pro 6.5s
Quad excessive amperage 350alts
4 juicebox 3100s
I use note cards. Smaller pieces taped together easier to work with. I think mine turned out pretty well.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Is your wall already built? For my wall, Alex and I kerf'd my box's side panels along my b pillar. I filled the 1/8 - 1/4" gap with foam, and body worked.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
To do it right you should pre plan for it. There isn't a drop of spray foam used to seal off my wall on the front face. I could get away with lot screws or anything if I really wanted to. It took me awhile to do it though and hand sanding to fit it perfect
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Nice, but i had to use all the space i could get. In order to do so, I needed to kerf the sides.
Wood wouldnt fit in 1/8" gaps.. well, without breaking. I couldnt do trim panels over the baffle either, due to my sub baskets and seat belts. My baffle is at a 42 degree angle and touches the back part of my seat belt bolt. I just dont have room haha.. Looking back, i suppose I couldve maybe done body filler. Wouldve been a pain bc i cant access it from the rear to apply any sort of pressure.
But its an eighth of an inch of gap that was filled lol
LMFAO so true
:blush:
Right different ways to do it. But I see too many people say I'm building a wall and not build in a way to seal it so they attach trim pieces to the front and things like that
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I couldnt possibly agree any more :good:
LMFAO so true
:blush:
