How to tell if music is clipped.
5VMgagl.png So is this clipped?
2003 Chevy Silverado Reg Cab. Rockford Fosgate 500a2 and Kicker ZR240 each on their own 12" Kicker Comp S. Small, but everyone's gotta start somewhere.
Wow.. I would say this is clipped.
You have no clue on what clipping is.
The wave will be cut off at the top and bottom of the wave.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
So Ryan. As you can see from the diagram above there are two kinds of clipping. They are caused by the signal being pushed to, and beyond it's limitations. Either by running out of electrical energy available or the limitations of the circuitry. A soft clip means you've nearly reached the end of the rope but still have a rounded, though compressed (limited) waveform. Some people like to push their electronics to soft clipping. Hard clipping means you've reached the absolute limits of your amplitude (volume.. measured up and down from the horizontal "zero" line). The waveform ends up being chopped (clipped) off at the top and the bottom due to the inability to produce the full wave. This hard clipping can destroy speakers by causing them to slam to a halt, slam into reverse, slam to a halt again, and so on.
How do I have no clue? I was obviously talking about the waves with heavy clipping to the right of my picture on the second one.
I wonder if those flat spots are due to the low resolution of the waveform representation. The only reason I wonder is because there are unclipped peaks with higher amplitude right next to the ones with the flat spots. Also because there are flat spots in the middle of the waveform away from the peaks in amplitude. I might be wrong though..
Screenshot_2016-03-19-06-20-08_zpsmg4vsh
Screenshot_2016-03-19-06-20-14_zpsfbjyqb
Search for Tony Ds videos. He does an excellent job of explaining this and many other things too.
Pioneer 80PRS
  • Who's Online   0 Members, 0 Anonymous, 869 Guests (See full list)
