dbackfan12 Posted March 19, 2016 Report Posted March 19, 2016 I was looking to add some more reserve to my build and was able to get a deal on a northstar NSB170 (thing weighs like 125 lbs) and I was going to use it with my XS power XP 3000 and D3400 under the hood on a singer 370 amp alternator. Im just wondering if I am going to run into problems by mixing different sized batteries? Should I have used another XP3000 instead?
MrSkippyJ Posted March 19, 2016 Report Posted March 19, 2016 As far as I know you should be just fine. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
ShadeTreeMechanic Posted March 19, 2016 Report Posted March 19, 2016 Different sized batteries are a problem in deep discharge situations like electric cars and solar banks and demos with engine off. As long as you play with the vehicle running and your voltage is up, you should be ok. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
dbackfan12 Posted March 19, 2016 Author Report Posted March 19, 2016 Well that is good to hear. I went to a shop a few weeks back and one of the guys there told me that using different batteries would result with messing up my alternator. I kinda thought he was full of it and I guess he was.
Rich Schenk Posted March 22, 2016 Report Posted March 22, 2016 U should be fine no different then u running.d3400 underhood and xp3000 in the back as long as batteries all all resting at same voltage no.difference On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
im_quagmire Posted March 31, 2016 Report Posted March 31, 2016 agm with agm you are fine. But What Do I Know? 2003 Chevy Monte Carlo SS 3.8 JVC KD-R975BTS Clarion EQS746 Kenwood P907PS Ascendant Audio 12" Havoc v.1 Ampere Audio 2000.1 MB Quart Onyx 800.4 XS Power D3400 - Hood XS Power D975 - Trunk Singer 240A Sky High OFC 0 & 4 gauge Kno Knoise Kolossus Deadener
MADVIBES Posted March 31, 2016 Report Posted March 31, 2016 If you ever want to fully charge each battery you would have to disconnect them from one another to get a complete charge. You can mix them all day long but you wont get some in the group to fully 100 percent charge, I have a dual bank charger for his purpose. but I am lazy and only do the seperate charges on the night before big comps. DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
