nativewelder217 Posted March 28, 2016 Report Posted March 28, 2016 Please help. Bought multi meter today. Need a walkthrough on where to check and how to check problems with connections. Fyi had 2 different subs recently and both worked fine on my setup. Just this new one won't work. This new one I built box and did all the sub wiring.
rockFord_Expedition Posted March 28, 2016 Report Posted March 28, 2016 Set multi meter to read ohms and hook it up to the subwoofer positive and negative Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
Bayuk89 Posted March 28, 2016 Report Posted March 28, 2016 If its a 4ohm voice coil its should read 3.6-3.8 ohms of resistance. If its a 2ohm voice coil it should read 1.6-1.8 ohms of resistance. This is a ROUGH estimate, but if your 4ohm sub is reading over 5ohms of resistance there is a problem....
ShadeTreeMechanic Posted March 28, 2016 Report Posted March 28, 2016 What kind of subs? Are they dual voice coil? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
MotorCityFats13 Posted March 28, 2016 Report Posted March 28, 2016 the OP liked his own comment.... LOL
nativewelder217 Posted March 29, 2016 Author Report Posted March 29, 2016 Hds 212 d2. Parralel wiring to 1000 watt punch Rockford to fosgate amp. 12 gauge wire. Seems big because all would not fit into subwoofer terminal.
Triticum Agricolam Posted March 29, 2016 Report Posted March 29, 2016 Hds 212 d2. Parralel wiring to 1000 watt punch Rockford to fosgate amp. 12 gauge wire. Seems big because all would not fit into subwoofer terminal. So what did the DMM show when you measure the resistance on the wires going to the sub? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
nativewelder217 Posted March 29, 2016 Author Report Posted March 29, 2016 From the terminal on the box I got 2.4 to 2.5
nativewelder217 Posted March 29, 2016 Author Report Posted March 29, 2016 Took sub out of box and checked the two terminals on the sub, one showed 2.8 and the other 2.9
bassaddiction Posted March 29, 2016 Report Posted March 29, 2016 Took sub out of box and checked the two terminals on the sub, one showed 2.8 and the other 2.9 touch the leads on meter together as hard as u can and tell me number
