Downfire and upfire sub wiring ?
truck dodge ram ex cab 2004. I have a custom downfiring sealed console with a JL 10w0v3-4. I am install two more same subs in a upfireing ported box under rear seat. amp will be a RF R1200-1D at 1ohm. question is will the console sub need to be wiring backwards as to + and - , so all three sub more the same direction.. whats your thoughts on a sealed and a ported box all running of same amp.
Wire them all the same and in parallel. I'm sure it will do something.
Pioneer 80PRS
I still don't know about this up firing alignment for a box under the rear seat. Should do forward firing with grills of you're worried about rear passengers kicking the speakers, and port to the d/s if you'er going ported.
