Fuse Blocks melting from Alternator to Rear Batteries
What makes you think you're even getting 8k?
hmm wouldnt the power going thru the wire to the rear batteries be only 300 amps or so? because thats what the alternator is capable of doing?
i guess 1/0 would not be enough for that but wondering about my questions for my own information
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
The 5500s didn't fare to well on the amp dyno to start . Real world numbers are almost always lower cause voltage drop and ohm raise.
He's got a clamp meter so I say let it eat and clamp that 1 run from the front and see what's being pulled through it.
Do you have a front battery as well op?
not sure if singer says to have multiple termiantions of wire on his charging posts, I know mechman recommends against it because they can possibly arc between each other
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
What is the voltage on rear batteries at full load? What type of connections are you using? The connections are getting hot because they are too small for the current they are pulling. The resistance across the connection goes up with current and when voltage is dropped across them they appear as a load and get hot. More runs of 1/0 will help by dividing the current across more connections. Dual inputs to the amps wouldn't hurt either.
Pioneer 80PRS
Yes. I have front battery too. And 4 in the back.
Would i get less ohm rise if the amps weren't strapped?
impedance rise is all related to the enclosure and cabin size @ the tune and has nothing to do with the amps and subs.... its just something everyone has to deal with and cant be stopped only way I know to combat this is design an enclosure around what a imsg and amm1 tells you when you play sweeps
It's called an impedance curve and every speaker has one regardless of the enclosure it's in.
  • Who's Online   0 Members, 0 Anonymous, 9337 Guests (See full list)
