Preamp for head unit.
Head unit pushes 5v it says, going to test tomorrow. Either way I wanted to get a eq, but it says 8v out. Amp says in stats it can only handle 6volt in. will i mess something up using that crossover?
What HU, EQ, and amp? Some EQs have an adjustable input.
Pioneer 80PRS
The head unit is a ppi double din dvd, eq will be the clarion EQS746, amp so far is a ppi black ice 2600.1 it might be changing for a 3500 watt dc really soon. Im more wondering about the output from the eq to the amp. if its only rated for say 6volt input if i slam 8 into it will it hurt it?
If your amp can only take as high as 6v input on the RCAs, and you input more than 6v, then you will be clipping the signal. So 8v=bad
Ty, thats the answer i was looking for, i will have to put a output adjuster on it.
Get a better head unit, one that has a decent eq.
The more stuff you add to the chain the more likely you are to introduce distortion.
  • Who's Online   0 Members, 0 Anonymous, 813 Guests (See full list)
