Please help me do this right guys..
OK smd world I'm saving up for an upgrade on my buick. I'm moving my audio legion 3500 3 xs power 3400 Batts and fi bl subs to my truck and redoing my set up in the car. I want to get either the sp4 12's or the DC xl 12's. I gotta hit up singer for a quote for an alt since mechman don't make one for my vehicle. What all would I need for that set up? Amp I will be using is gona be the bC 5500 or the sundown 6k. How many Batts and size alt would I need ? I'm obviously gona need 2 runs from alt to Batts in the back with solid grounds just don't know what kind of alt or batts I need.
I seen they sale an xs power d7500 would one of those and maybe an xp3000 in the back with a s3400 in the front ?
Sure if you are okay with having two kinds of batteries in the back
Ummm... Lets see...
6k rms.. is that along with mids and highs? or are you just accounting for bass? Im going to assume that youll be running at least another 1k in mids/highs
7krms..
Im more than positive that you can NOT fit a 7500 under the hood of your car. Your best bet is to go with a 3400 under hood, and 4 XP3000 in the rear. Alt you'll want to get the most productive, NOT BIGGEST, that will work in your vehicle. Lower RPM power is more important. As long as you can charge your reserves at a lower RPM you will be fine. A lot of people assume bigger is better, in some setups, yes, but for daily driving around town or a work commute, you'll be fine. You may want to look into running a dual bracket if possible, and get even more efficiency out of your charge.
But What Do I Know?
2003 Chevy Monte Carlo SS 3.8
  • JVC KD-R975BTS
  • Clarion EQS746
  • Kenwood P907PS
  • Ascendant Audio 12" Havoc v.1
  • Ampere Audio 2000.1
  • MB Quart Onyx 800.4
  • XS Power D3400 - Hood
  • XS Power D975 - Trunk
  • Singer 240A
  • Sky High OFC 0 & 4 gauge
  • Kno Knoise Kolossus Deadener
^didn't say he was going to put the 7500 in the front, and how many bigger alts have you ever seen that have lower output at low RPM's than a smaller alt? Also how much space do you have in your trunk? A box for multiple sp4s or XLs, a big ass amp, and then a couple batteries is going to take up some room.
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
Ummm... Lets see...
7krms..
Lower rpm is not that important unless you plan on playing at idle or below 1200rpm at full tilt, which most don't. Im not saying you should get a 400a alt that doesnt do jack shit at idle, but if 99% of your high volume play is when your vehicle is at 1500+ rpm... well, you arent looking for idle output.
Ummm... Lets see...
7krms..
But What Do I Know?
  • JVC KD-R975BTS
  • Clarion EQS746
  • Kenwood P907PS
  • Singer 240A
  • Who's Online   0 Members, 0 Anonymous, 901 Guests (See full list)
