Rich Schenk Posted April 28, 2016 Author Report Posted April 28, 2016 That's what I was thinking because I had zero noise and no alt whine now I have both . Think when it popped took out my last working tweeter. Thankfully I haven't installed my new ones yet. makes popping when turned to volume 0 changing source, going to Bluetooth phone etc u get popping. Don't understand why he would just screw-up out of nowhere anyone else experience this issue with pioneer 80prs wonder if it's from bass. Going to start by switching out hu with kenwood screen to see if that works. Hoping it's hu because I believe with sonicelectronix there's a year warranty Quote On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Jhunt94 Posted April 28, 2016 Report Posted April 28, 2016 That's odd, I don't believe I've ever had my 80prs pop when switching sources. Quote 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
3vil Posted April 28, 2016 Report Posted April 28, 2016 Is it possible he blew the pico fuse? I've heard of Pioneer decks picking up ground loop noise after the fuse blows, but I haven't heard of it sending amps into protect. Here's a write up on the repair, just in case it is the problem. http://www.stevemeadedesigns.com/board/topic/44297-howto-properly-fix-your-pioneers-rca-ground/?&hl=fuse Quote
reedal Posted April 28, 2016 Report Posted April 28, 2016 Is it possible he blew the pico fuse? I've heard of Pioneer decks picking up ground loop noise after the fuse blows, but I haven't heard of it sending amps into protect. Here's a write up on the repair, just in case it is the problem. http://www.stevemeadedesigns.com/board/topic/44297-howto-properly-fix-your-pioneers-rca-ground/?&hl=fuse That's what popped into my head. If the excess noise disappears when he uses the kenwood, and the 5k stops protecting with RCA's plugged in, then that would definitely be my guess. Since the amp comes out of protect with the RCA's unplugged, that leads me to believe it's something in the line of those. How did it test when you took the LC-1 out of the loop? Quote SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Rich Schenk Posted April 28, 2016 Author Report Posted April 28, 2016 Haven't tested anything besides what I intialy did will try and work on it today strongly thinking its defective hu. Found this on Google one of the first things that popped up. http://www.caraudio.com/forums/head-units/550087-pioneer-80-prs-issues.html Quote On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Rich Schenk Posted April 28, 2016 Author Report Posted April 28, 2016 Doesn't make sense for Pico fuse to blow out of nowhere. have never hot swaped rcas because I know pioneers our notorious for blowing them Quote On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
reedal Posted April 28, 2016 Report Posted April 28, 2016 You may not hot swapped, I'm leaning towards the LC-1 being the issue and possibly blowing the pico. There was a recent LC-1 issue thread, where one of the wires inside of it had broken it's connection and caused problems. Take the LC-1 out of play, and see if your amp still protects. If you're still getting noise but your amp no longer protects with RCA's plugged in, then it's probably the pico. If amp still protects, swap HU's and try again. Quote SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Kyblack76 Posted April 28, 2016 Report Posted April 28, 2016 Wait. I thought there was one amp in protect and one with suden noise ? 2 amps, 2 problems? Did I wake and bake a lil to hard today and miss read? 1 Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
reedal Posted April 28, 2016 Report Posted April 28, 2016 No you're right Kyle. One amp in protect, one with noise. Sorry if my explanation wasn't clear on that. Quote SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Rich Schenk Posted April 28, 2016 Author Report Posted April 28, 2016 Dc 5K in protect with rcas in Mmats sq4100 no protection noise and alt wine Skar sk85.4 no protection noise and alt whine Quote On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
