DC Sound Lab
dc 5k protect issue. amp tested 100% fine why is this happening?
i have a dc 5k that all asudden wen into protect mode and dont understand why? was driving my truck bumpin at low volume and all assuden i hear a pop. have noise out of nowhere the mids and highs. and pop noise when i change the source and dc 5k is in protect. i turned of system multiple times to see if it was a fluke thing wont go away. checked fuses in back 14.8 across both sides of fuses. remote turn on is 14.8v as well. voltage is fine at amp so thats not the issue. protect light is on amp. stays constant turning when turning on. goes away if you unplug rcas and just green light. but still have mids and highs with noise. dont know if this is a amp issue or headunit issue leaning towards replacing rcas. bad rcas or defective hu. any help would be appreciated. none of my other 2 amps for mids and twereters our in protect they our playing fine except for the noise.
Edited by Rich Schenk
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
What load are you running to it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
tuned in as I am gonna be running this amp as well
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
The subs 1 ohm as it has always been on this amp
Or could it be the lc1?
Process of elimination, unplug LC1 and go from there. unplug highs/mids amps one at a time. I have no idea what the problem could be just try and narrow it down if you don't have extra HU to try
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Run different RCA's over the interior one at a time to see, seems weird though that it comes through all speakers and your sub amp is in protect....=O
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
I know it's messed up going to work on it tomorrow? Any other ideas and solutions welcome
Like other have suggested, just start doing the pieces of elimination. Bypass your LOC and feed signal straight to one amp. If it works, do the same with the other amp. If it doesn't work try a new set of rca's. If that won't work try a 3.5mm to rca straight to one amp then the other.
First step is localizing the issue to the Headunit, LOC, or amplifier(s)
Edited by 3vil
  • Who's Online   1 Member, 0 Anonymous, 1761 Guests (See full list)
