Kyblack76 Posted May 3, 2016 Report Posted May 3, 2016 Hell ya. Even with quad hair pins, our bat reserve is weak at best. And I don't like it want more reserve for sure SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
magillaru Posted May 3, 2016 Report Posted May 3, 2016 Hell ya. Even with quad hair pins, our bat reserve is weak at best. And I don't like it want more reserve for sureThis is a perfect example. Perfect alt setup but I guarantee those alts are working their asses off due to the low reserve. Bottom line, OP, get whichever alt will best suit your needs (high rpm vs idle) and up your batt bank as needed. I'd start by adding at least one more and keep adding until your voltage stabilizes. Singer Alternators Team Asshole #anothershittysingerbuild
RooTxBeeR Posted May 4, 2016 Report Posted May 4, 2016 A 370 will do just fine at idle but the 270s are monsters. I'd want a couple more batts for the reserve....the alt is there to supply your battery bank.....you can't rely on the alt to do all the work unless you want to stress the hell out of it. Or you have more than enough alt for what your current draw is. But good luck doing that with today's high wattage systems lol On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
magillaru Posted May 4, 2016 Report Posted May 4, 2016 A 370 will do just fine at idle but the 270s are monsters. I'd want a couple more batts for the reserve....the alt is there to supply your battery bank.....you can't rely on the alt to do all the work unless you want to stress the hell out of it.Or you have more than enough alt for what your current draw is. But good luck doing that with today's high wattage systems lolThis is true lol I just wanted to point out that there's more to it than just having the biggest alt you can fit under the hood. For example a vehicle that idles around 5-600 rpm that can fit a 320 is gonna eat shit at idle with that 320. Throw a 270 in there and it will hold voltage all day as long as you have a decent reserve. Which leads into my other point. You can have a triple/quad alt setup with shitty reserve and you may have enough alt for what you need but without the reserve, those alts are going to be working so damn hard, you would've been better off with less alt and more reserve. Singer Alternators Team Asshole #anothershittysingerbuild
magillaru Posted May 4, 2016 Report Posted May 4, 2016 The 370 is a monster alt but it might not be the best option in some applications. For example if you plan on playing at idle most of the time in a vehicle that idles low. The 270 will likely provide you with the same power the 370 would in the same application. Singer Alternators Team Asshole #anothershittysingerbuild
