RageQuitForLife Posted May 7, 2016 Report Posted May 7, 2016 about to buy wire to upgrade my big 3, but cant find any forums or information that say what size fuse i need for the wire. the alternator is 145 amps if that helps.
300824 Posted May 7, 2016 Report Posted May 7, 2016 you fuse for the wire... use ofc wire or welding wire. i have welding wire for all my power wires.
RageQuitForLife Posted May 7, 2016 Author Report Posted May 7, 2016 you fuse for the wire... use ofc wire or welding wire. i have welding wire for all my power wires. i understand that but i was told that you that you still need to fuse the power wire for the big 3. im buying sky high ofc but i dont know what fuse size i need
ChevyBoy95 Posted May 7, 2016 Report Posted May 7, 2016 250a or 300a fuse will be fine for 1/0 OFC. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Broke_Audio_Addict Posted May 7, 2016 Report Posted May 7, 2016 No reason to fuse it higher than what the alt can put out, I'd use a 150 amp fuse. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
RageQuitForLife Posted May 7, 2016 Author Report Posted May 7, 2016 ugh, so many different answers i dont know which one is the most correct. one of you says 250-300 and one says 150...
Broke_Audio_Addict Posted May 7, 2016 Report Posted May 7, 2016 If you fuse to high you defeat the whole purpose of having a fuse.... That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
MrSkippyJ Posted May 7, 2016 Report Posted May 7, 2016 145 amp alt, i would go with a 150 amp fuse. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
RageQuitForLife Posted May 7, 2016 Author Report Posted May 7, 2016 ok that makes sense. im also looking at buying a crescendo s1500.1 for my subs, but i dont know which specs i need to look at to calculate the fuse that i would need. is it the volts x amperes = watts to figure out the fuse size?
