kichan Posted May 15, 2016 Report Posted May 15, 2016 Which one should i get as a second battery ... i have a d3400 under the hood but that one isnt enough to push my 4500 watt RMS sound system
Karkov Posted May 15, 2016 Report Posted May 15, 2016 Alternator > battery the XP3000 is a larger battery 120 ah > 75 ah XP3000 > D6500 Your alt does all the work from battery resting voltage and up, that's all on alt power. Until you dip as low as battery resting voltage your batteries are doing nothing. How low are you dropping? Your batteries will help maintain a certain voltage if your alt can't keep up. 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
kichan Posted May 15, 2016 Author Report Posted May 15, 2016 Im dropping like 11.5 ....and right now i have a 240 amp mechman alternator and big 3 upgrade and the d3400 and still have voltage drop ... so do you think the xp3000 would help with my voltage drop?
ToNasty Posted May 15, 2016 Report Posted May 15, 2016 Xp series is strictly secondary battery. D series can be used as both ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Karkov Posted May 15, 2016 Report Posted May 15, 2016 What ohm load is the amp wired to? Yes, a XP3000 would help you not drop so low, from about 13 volts and down you would drop much slower down to 11.5 if ever even get that low at all with the XP3000 Like ^^ he said, D series can go under hood and such where as XP series must be like inside cabin and what not. Sounds like you have already done all the prereq stuff and now you are at the point where yes, just add a battery and watch voltage 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
kichan Posted May 16, 2016 Author Report Posted May 16, 2016 Well i have 2 sundown audio x18 wired at 1 ohm i got it hook to a sundown svc 3000d. Also i have 4 crescendo 10 inch pwx's runing two speakers at 2 ohms per channel in a crescendo symphony 1100/2 and a pair of 6.5 inch pwx in a symphony 550/2 at 2 ohms in one channel
Mr DeeBeez Posted May 16, 2016 Report Posted May 16, 2016 You have almost the same electrical setup I have. I have a 240a mechman, d3400 under hood and an xp3000 in the back. Have a soundqubed 3500 at half ohm and it doesn't drop below 13. The xp3000 would do great. Fi Team 18's (4) Crossfire 16k Crossfire 400.4 & 800.4 Pioneer AVH-X491bhs 140ah cmax CES 320's (2)
Nightshade Posted May 16, 2016 Report Posted May 16, 2016 No VS threads!!! I like the xp for daily and d series for spl and daily. However, these two batts aren't even in the same category as far as output goes. The xp3000 is the stronger of the two by far. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
Karkov Posted May 16, 2016 Report Posted May 16, 2016 Not a "VS" thread within same manufacturer. 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
kichan Posted May 16, 2016 Author Report Posted May 16, 2016 Well it looks like im going with the xp 3000 ...... thank you all for your help
