Just installed an OM-1. Couldn't find a constant power source behind the dash, so I joined the constant power and remote power wires from the OM-1 to an "accessory on" wire from a 12V outlet. Is this bad news, or does it really make any difference. I'm not sure why the OM-1 needs a constant power supply... Thanks for your help!
Hey! Thanks for your reply. That was my plan, and I had a fuse-tap on hand, but it's in a 2015 F150, and the fuse box is using ATL fuses, so I don't think my ATM fuse tap will work... Searched for a constant on, and finally gave up... I'm just worried that the "accessory on" power-ups are going to fry the OM-1 after a half-dozen start ups... Can uninstall and rewire if I have to, but it's not an easy fix. Would be nice if it was cool the way I've got it...
Edited by Jammer_BC
I ran 14ga primary wire for power, ground, and remote turn on from my dash to my amps. Small gauge wire like that is easy to run that long and hide.
Edit: clarification: from my OM-1 and VM-1 in the dash, back to my sub amp which is what they are connected to.
Edited by reedal
Hell, you have a battery in the vehicle yes?
Nah, caps bruh
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
What a gong show... Turns out I had constant power, needed accessory power. Ended up taking out the dash media unit, uninstalled my new gauges, dug around with a test light for another hour or so... No idea where any accessory power is in that s.o.b... Guess the head unit comes on by magic. Anyway, ended up putting in a rocker switch wired from a DC outlet to use as remote-on, installed permanent usb outlet there, powers OM-1 and Volt meter... Now can kill charge outlet and meters when parked or when not wanted. These new cars are a PIA.
  • Who's Online   1 Member, 0 Anonymous, 1917 Guests (See full list)
