Running 2 PBR' s rated 125x2 , birth sheet was 132x2
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
If I do the JL amp they will get 100RMS but If I go with the Alpine F6 theyll get 150RMS
Car: 2012 Acura TL Elite
Head Unit: JL Audio Fix86
Front Stage : Alpine SPX-17PRO
Rear Stage : Alpine SPR-60C
Component Amp : JL Audio HD 600/4
Sub : 1 12" JL Audio W7
Sub Amp : JL Audio HD 1200
I would go with more power can always turn the gain down alittle . Would be nice clean power then very little stress on amp.
guess i suck at posting
. Lol
Could I do this option. Run the 6.5" Type R components in the front and Type R 6.5" coaxials in the rear deck off the Alpine PDXF6. And then have the 4" Alpine Type S coaxils run off my factory amp?
I wouldn't see why not .
You don't need the 4" speakers,
Run components in the front and a set of coaxial's in the rears if you want rears and all you need is a 4 channel amp,
Don't over complicate it.
Here you go,
All you need right here.
I'll take a thank you for saving you $900.
http://www.sonicelectronix.com/item_99843_Alpine-NVX-Full-Range-High-Performance-Amplified-System-w-6.5-Speakers.html
In case your curious about what kind of power the nvx amp puts out.
http://youtu.be/n-PvO58FO_I
Would you recommend the NVX JAD800.4 over the Alpine PDXF6? How are NVX products like subs, speakers, and amps?
Was mainly looking at the V or X series components up front with the V series coaxial in the rear. How would the compare to the Type R?
