[Willing to pay] I need help making a box
Prevail
I want to make a box for my sundown e12 v3 500w. I have no clue about anything when it comes to boxes and subs and I want someone to help me out. I don't know what type of box, but I mainly listen to hip-hop. Like g ezy, kid cudi, kanye west. The sun is a dual 2-ohm
Here's approximate dimensions of the trunk of my 1998 toyota camry.
in the first picture, there's a little space at the back? I don't know if I'd put the box there or not so I gave dimensions of that area and the area outside of it
http://i.imgur.com/tYHBWL0.jpg
http://i.imgur.com/Cubp0NQ.jpg
Located near Omaha, NE
Where are you located
Clarion cz702
Ssa evil mids and tweeters
ppi 900.4
2 zcon 18s
Taramps 10k
3 big dekas 1 xs
3 runs of 4/0 and big 3
300+ amp ohio generator
155.7 on dash at 36 (peak) 152 at 25
I have the same exact sub in my wife's Civic. It depends on where you are located to get someone to help you build a box. That info would be good.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
There are a lot of good people on this fourm that are willing to help you out. All they need is your Max demensions, year and make of vehicle, power, sub model etc. they're quick too, and you learn a lot in the process of building your own box brother. Stick around this fourm and you'll learn a lot
Team Bass-Hz
Near Omaha, NE.
I don't necessarily need it to be made for me. Just layout and dimensions and then I can pay some place to make it, too. But whatever works.
Here is a suggestion, sub / port firing back, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 2 1/4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
  • Who's Online   1 Member, 0 Anonymous, 3220 Guests (See full list)
